PVC 110 top - Defender Source
Old November 17th, 2013, 05:42 PM
l.a.rover
handy andy
73 Land Rover 88 Lightweight
PVC 110 top
Just converted my 110 from hard to soft... I was installing the top and I can't seem to get it to fit right. From wat it looks like ... It won't stretch into place...
Does anyone have any ideas and/ or advice? I have removed and refitted it three times to no avail!!!!
Old November 17th, 2013, 06:22 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Get a space heater and put in the garage over night! Get it nice and hot! It should stretch enough to fit! Hopefully that helps
Old November 17th, 2013, 06:34 PM
ssi19's Avatar
ssi19
scott
1995/D90
Zip all the windows in (when the top is off the truck) and then slide it over the cage. Attach what you can (I usually opt for the belt rail over the windshield first. Then get the truck in the sun, turn the heat on, use the space heater like brewie said etc. After about an hour of mega heat put on some gloves and stretch it into place. It'll take some elbow grease but this is the tactic that works.
110, top
Defender 110 Full Soft Top w/ Stick Set SafariHP The Vendors Loft 1 June 22nd, 2012 05:15 PM
110 rear top sides Doug Crowther Wanted 6 December 4th, 2007 02:19 PM
90 and 110 Top sides the same? PCRover Defender Technical Discussions 3 November 5th, 2007 09:26 AM
FS: NAS Fiberglass Top, NYC area NASD90 For Sale - Parts 1 September 1st, 2004 05:17 PM
