Puzzler - Defender Source
Old April 7th, 2011, 12:21 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Puzzler
Whats wrong with this picture?
Discuss
300 tdi timing belt
legend in my own mind
Old April 7th, 2011, 12:34 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Belt is walking and there is no shoulder on the gear or pulley.
The pulley looks different then mine as the bolt is bit recessed in the pulley. looks like the 200....
Old April 7th, 2011, 12:45 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Chicken dinner
You are looking at an early idler pulley on the left above the crank gear. The right idler pulley above the crank gear is the later style. If it were an early style it would have a lip. And the crank gear is indeed an early style without lip. Worst combination of parts available.
The early style idler pulley that was provided above the crank gear to right had a retention lip to it. LR determined this to contribute to early belt failure and updated the parts to use a crank gear with retention lips.
Hard to notice in the picture. the camshaft gear was also off a tick. This is a common mistake that is overlooked if the belt is not rotated and double checked after initial fitting.
Old April 7th, 2011, 01:05 PM
D90user's Avatar
D90user
steve
What do I get... the motor??
When they are off one tooth is there a noticeable difference in engine sound/power? I would think so.
Old April 7th, 2011, 02:12 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Yes. performance drops right off.
