Putting windows in a van side panels need template - Defender Source
Old March 22nd, 2009, 10:30 PM
Looks like I just bought Ren Ching's hand top. I have some fixed windows out of a fiberglass top and want to install them. Anyone have measurements or a template so I can put them in the right place?
Also, will a sawzall work to cut the hole?
Old March 22nd, 2009, 10:39 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I think a sawzall will damage the sides, but you might be able to get away with it if you try a really fine tooth blade.
Maybe a nibbler or mark them and have someone with a plasma cut them?
Is the location the same as a SW side? I need a template for a factory SW
Old March 22nd, 2009, 11:18 PM
I want them the same as on a factory SW. They are the same size, they just don't open. If you find that template, I would like a copy.
Ron
PS might have to buy a nibbler.
Old March 22nd, 2009, 11:23 PM
bstraw's Avatar
bstraw
Byron Straw
1994 POE/ST
Ron, would a template out of the fiberglass top work or are they different? Also, what about water jet cutting?
Old March 22nd, 2009, 11:35 PM
Fiberglass is different. Water jet would cost more than the top.
Ron
Old March 22nd, 2009, 11:59 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
If anyone in Colorado has one I can copy I would be happy to share it with you.
Old March 23rd, 2009, 06:12 AM
LenB did exactly what you are talking about. Shoot him a PM.
Old March 23rd, 2009, 07:51 AM
I'd say if you can clamp a 2x4 (both sides) as both a guide and stiffener, it will cut fine with a sawsall, fine tooth blade, gentle touch and patience.... Oh who am I kidding. No Ron.
charles
Old March 23rd, 2009, 08:45 AM
jigsaw is probably better. they did one in one of the mags a few years ago. starting hole for the blade was done with a hatchet. they just put the window up, trace around it, then move the line in by 1/2" or just over the thickness of the mounting flange. the flange on my windows and one the ones madcow bought looked to be about 3/4" so the hole does not have to be perfect.
ron are you saying the tupperware-top windows do not open? I would look for some sliders if that is the case. something like this maybe:
http://cgi.ebay.com/ebaymotors/Windo...mZ260303602922
or...
http://www.hehr-international.com/1900vanhome.htm
charles
Old March 23rd, 2009, 09:59 AM
I don't want sliders.
Ron
Old March 23rd, 2009, 10:29 AM
aah, ok. security issue? or just personal preference? I always wished my 109 had sliders to let some more air in/out.
Ron
Old March 23rd, 2009, 10:31 AM
No, just preference. Sliders rattle and break.
Old March 23rd, 2009, 11:49 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Sliders rattle
Same reason I am going to go with solid windows, most of the SW's I have been in the windows would rattle and leak.
If I change my mind and want the airflow later I can always install sliders
Old March 23rd, 2009, 01:03 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
A Sawzall is a dis-truction tool! VERY difficult to control under the best of circumstances !! I'd use a variable speed jig saw myself, with a new, very fine blade. Also, I'd duct tape over the whole area 1st, then draw my cut line on the duct tape. The fine cuttings will get under the saw and scratch the crap out of the finish on the paint. If possible, do it on the inside surface. Also, aluminum will tend to "gaul or load up" the blade, so the blade needs so type of lubrication on it to prevent this situation.
Dennis
Old March 23rd, 2009, 03:17 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
use a thin cut off wheel on an air grinder...
Legend in My Own Mind.
Old March 23rd, 2009, 03:26 PM
Does it matter that I plan to paint after I cut?
Old March 23rd, 2009, 03:30 PM
It's more about warping/bending the metal and the fact that aluminum likes to clog blades. A grinder with a cutting blade is probably the least damaging. Otherwise use a jigsaw and some fresh blades, but I'd still clamp some 2x4s to stiffen it and give you a guide edge.
I would mask the area with blue painters tape or the like. you don't want any gouging caused by swarf getting under the shoe. Since they are off the car it should be pretty easy to just lay em flat and do a nice cut with a jigsaw. That is how I mostly did the cut for the bulkhead bar. if you get the template ready I can maybe borrow my neighbors jigsaw when I come up.
Old March 23rd, 2009, 03:35 PM
I have a jigsaw somewhere.
Old March 23rd, 2009, 08:51 PM
My vote would be for a plasma cutter or a cut-off wheel.
panels, window, windows
Factory New SW sliding side windows dave_lucas For Sale - Parts 7 October 6th, 2009 07:45 PM
Side Zip-out Windows from Soft Top gamberik For Sale - Parts 7 March 5th, 2005 09:59 PM
Wanted: fiberglass ht side panels & liftgate jaherring Wanted 2 November 15th, 2004 11:02 AM
D90 SW side panels wanted Chris Cox Wanted 0 August 31st, 2004 06:23 PM
SW top and side panels Chris Cox Wanted 4 August 14th, 2004 03:29 PM
