Putting her in gear problems - Defender Source
Old November 1st, 2010, 02:29 PM
jijalicious
Jiman Khosravan
'94 D90
Unhappy Putting her in gear problems
[94 D90 manual r380 3.9L]
Afternoon wise people of D-90...
I'm having some problems going from neutral to 1st or 2nd gear...
It gets stuck.. and i have to try multiple times to get her in gear and it sounds horrible when it doesn't catch it.. grinding sound....hate it.
I remember someone had similar problems and the problem was in the clutch disk? Does that make any sense? And there was pictures posted of how they replaced the flywheel cause the teeth had all worn out.
Or in other words... where would you look if it's hard to put her in gear?
~Jim
Old November 1st, 2010, 02:47 PM
Is it better if you pump the clutch a few times before trying?
Are you losing any clutch fliud from the master (ie is the level down)?
Old November 11th, 2010, 10:30 AM
sel
steven lewis
1994 D-90
where does one check the master fluid level??
Old November 11th, 2010, 12:55 PM
michael67's Avatar
michael67
Michael White
110 Tdi
Open the clutch master cylinder reservoir cap and look inside is the normal method. The clutch master cylinder is near the brake master cylinder. On mine, it's very near the firewall and fender. You may want to download a service manual or two...
Old November 12th, 2010, 02:57 PM
jijalicious
Jiman Khosravan
'94 D90
Thanks guys... I'll check the levels and look inside the reservoir cap.
~Ji
Old November 12th, 2010, 03:44 PM
Try pumping the clutch pedal too. If there is a leak (low fluid) or pumping helps, it is likely the master or the slave. Replace both and the lines.
Old November 12th, 2010, 03:56 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
hi Jim, if it is not losing fluid try this before tearing into the tranny.. clamp the rubber flexy pipe to the clutch slave on the tranny and then press the clutch peddle and hold it for about a minute if it slowly goes down the seals in the clutch master are shot and passing fluid past the pressure seal
regards
problems
Gear ratios - 1995 NAS Defender? jam90 Defender Technical Discussions 3 February 19th, 2006 03:58 PM
Weird burning smell in 5th gear? oldscratchggf Defender Technical Discussions 7 February 14th, 2006 09:09 AM
LT230 Input gear again! Mike Hippert Defender Technical Discussions 17 June 19th, 2005 06:45 PM
Speedo Gear Removal 48vphantom Defender Technical Discussions 2 March 27th, 2005 02:51 AM
