Putting front light surrounds on an exmod 90 - Defender Source
Old September 11th, 2013, 02:24 PM
meow
Johnny
'87 90
Hey does anyone have pics or anything of how to removes the front parking lights and turn signals on an exmod 90, not just the lenses?
Also for the bolts that hold the bezel on, are the nuts usually part of the body panel or are those some kind of clip on nuts I can buy somewhere?
Thanks.
Johnny
Old September 11th, 2013, 04:05 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Thanks.
Johnny
I did this. Pull the lenses and bulbs. Three screws hold the metal bezel to the body. No nuts or bolts. Small screws. Pull on the bezel and you will expose the rubber enclosure of the light socket. Just wiggle it back and forth and the whole damn thing will pop out.
Just cautious of pulling on the wires too hard the ex mod trucks have wires tapped to wires tapped to connectors etc. if you inadvertently pull a wire out of its connection you may have to spend DAYS figuring out where the hell it attaches to.
If you have specific questions about upgrading lights, headlight bowls etc I can help. Just PM me.
Josh
Old September 11th, 2013, 04:11 PM
josh-man's Avatar
josh-man
joshua
As a follow up; rovers north has the square threaded inserts that pop in to those square punch outs in the sheet metal. You need 4 plus the small bolts. No nuts. The upgraded lenses screw on THROUGH the plastic headlight surrounds to hold that side of the plastic piece on.
Here is a before and after...
Old September 11th, 2013, 04:49 PM
meow
Johnny
'87 90
Awesome, thanks guys.
Old September 11th, 2013, 04:55 PM
josh-man's Avatar
josh-man
joshua
Did you buy the correct surrounds??
Old September 11th, 2013, 05:10 PM
meow
Johnny
'87 90
I haven't bought them yet, wanted to see how hard it was going to be to replace the lights.
I'm going to get these :
https://landroverparts.roversnorth.c...=PLC929&type=0
https://landroverparts.roversnorth.c...=PLC928&type=0
Old September 11th, 2013, 06:00 PM
josh-man's Avatar
josh-man
joshua
Replacing the lights is easy. Rovers north has them.
So you need your four lamps (2 clear 2 amber) the plastic nut inserts, the bolts that go into them to hold the plastic surrounds on and the surround pieces you link to. I was sent what I was TOLD was the correct ones but turns out they were for a different year and the hole cut outs didn't line up.
You cannot re use the screws that hold the MOD light bezels on, they are too short to go through the new lamps, plastic surround and then into the metal. Hit Home Depot for a 1" stainless version of the same screw which will give you plenty of room.
Next and last thing is wire crimp connectors (not sure what they are exactly called) See how the lamps come they may already have male ends crimped on so you can just buy the matching female ends and splice them in. Heat shrink them if you can.
The lamps don't come with bulbs but you can reuse the bulbs from the mod fixtures (at least mine didn't). The new fixtures have a funky metal grounding tab that the screw needs to go through before it attaches to the truck. Maybe it's obvious to others but I wired it up and put a bulb in the fixture and turned the directional on to test my connections without screwing it to the truc it didn't work. I though I had a bad bulb but then realized that when you bend the metal tab to the position that would allow you to put a screw through it and then through the plastic fixture, it makes the appropriate connection and will work (as long as its wired properly).
Hope that may save you some heartache!
Old September 11th, 2013, 06:46 PM
meow
Johnny
'87 90
Thanks for the help, I'll check it out tonight.
Old September 14th, 2013, 10:19 PM
josh-man's Avatar
josh-man
joshua
Also keep in mind S3 surrounds work too if you like less plastic.
-Jeff
Jeff I like that look too. Are those surrounds metal?
Old September 14th, 2013, 10:47 PM
josh-man's Avatar
josh-man
joshua
Yes. LR birmabright. You could even polish them if you like the 'chrome look'.
-Jeff
Hah yeah you know me, king of the "bling" ahahha
90, d 90, ht, mod
Front seats from a 90 grey vinyl chasrover For Sale - Parts 0 January 19th, 2013 10:41 PM
Front Light Bar wanted Joe_in_OH Wanted 1 January 1st, 2010 04:28 PM
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
Front parking light assembly? Burke Defender Technical Discussions 6 September 17th, 2009 09:40 PM
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
» Defender Registry
Defender
JAG
Viking
atakan
Add your Defender
