Putting a 4.6 in my 97 D90 - Defender Source
Old December 18th, 2010, 10:14 AM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
So I found a brand new 4.6 Rover short block to swap into my D90. I'll be using my original heads and basically all the good parts off my old engine, got a new 4.6 camshaft, lifters, timing kit, hose kit. I have been told though that the engine will run fine without any modifications but it will run better with a 4.6 chip in the ecu. Can anyone advise me on rechipping my ecu and where I can get a chip for a good price (>$500). Perhaps I can get one out of a salvaged 4.6 P38?
------ Follow up post added December 18th, 2010 11:16 AM ------
less than $500 *
Old December 18th, 2010, 12:43 PM
The Dro
Dro
1988 Ninety
You do not need a new ECU. GEMS ECU ('96-99) are the same for both 4.0L and 4.6L motors.
Tell the mechanic that is doing the swap to change the ECU settings from 4.0 to 4.6 in the petrol engine management settings screen with AutoLogic.
Carlos and I did it on my 4.6L
Old December 18th, 2010, 12:53 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Have Rod Dassler at Rovers down south "fix" your heads you will be much happier with the performance.
Keith
Big, Red and ... aaa Red..
Old December 18th, 2010, 01:17 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Why you're do'n all this you might as well cut the trumpets down. It gets rid of that top end lag/wall you hit when you're get'n on it. 3/4 of an inch....less than that doesn't do much,but more than that seems to mess with the bottom end push. Your ECU will adapt fine, but change over from 4.0 to 4.6 internally with Testbook,Auto logic,Rovacom,ect. Good luck.
Old December 18th, 2010, 04:54 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
This is a myth.
The P38 ECUs contain the programs for both 4.0 and 4.6, but the stock NAS 1997 Defender ECU only has a 4.0 program in it. It does not contain a 4.6 set up.
Yes, it still retains the P38s ability to switch back and forth between 4.0 and 4.6 on the Autologic screen, but it does nothing in a 1997 NAS Defender ECU.
You just changed the number on the screen. You did not change any parameters or anything useful.
In working with Mark Adams of Tornado systems here at ECR I have seen the inner workings of the GEMS set up and there ain't nothing for a 4.6 in there, sorry.
Email:
Old December 18th, 2010, 05:56 PM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
I put in the 4.6 chips and my idle went to 600 rpm and I do feel a difference in power . The 90 accelerates alot smoother but I did get an error code for transmission security check . I then started to play with both chip set and now the code is clear . The solution was to change only the bigger of the two chips and the code cleared, LR tech stated that the bigger chip controls the engine and the smaller chip the ancillaries . All this was done at LR dealer using their diagnostic laptop . They set the parameters to 4.6 and concurred with ECR's statement that the chip must be replace . My 90 is quicker and a lot smoother . Just did this upgrade about 3 weeks ago and so far everything is fine .
Old December 22nd, 2010, 11:13 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
Still, could I get a 4.6 chip out of a salvaged/junked p38 or something of the like? Don't have big bucks to drop on a brand new little chip. My 4.6 should run fine w/ the 4.0 in there anyways right?
90, 97, 97 d90, d90, ecu, rechipping
97 LR D90 with callaway 4.6 and everything for sale Outsidr For Sale - Vehicles 4 March 6th, 2009 03:20 PM
clutch for 95 d90 w/ 4.6 vesparover Defender Technical Discussions 7 January 4th, 2006 11:09 AM
headers for '97 D90 mdmccallum Defender Technical Discussions 43 April 25th, 2005 10:23 AM
I've Got A 97 D90 Frame That was just Galvanized ksteven Defender Technical Discussions 21 March 24th, 2005 11:22 AM
97 D90 maxing out at ~70mph?? vnrover Defender Technical Discussions 3 November 10th, 2003 02:14 PM
