purpose of relays? - Defender Source
Old October 14th, 2014, 10:39 AM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
purpose of relays?
Anybody willing to tell me the purpose of the two square relays (fuses, whatever) under passenger seat?
I can't find a diagram. Square, right next to each other about 1 inch by 1 inch?
1995 NAS Wagon...
Attributed to Shayne...
Old October 14th, 2014, 10:42 AM
fuel pump
Old October 14th, 2014, 10:48 AM
Fuel pump. Isn't it in the owners manual?
Old October 14th, 2014, 10:52 AM
kevincdoyle
Kevin C. Doyle
prolly...but..
don't have one at the office...
Why would one of them get hot to the touch and the other not?
Old October 14th, 2014, 10:53 AM
You're touching them in your office and one is hot and the other is not? Are we still talking about relays?
Old October 14th, 2014, 11:04 AM
kevincdoyle
Kevin C. Doyle
Hah!
Exactly...
I now have 3 issues with the 90 although I think the ignition switch is an easy fix, a bit more worried about the rear half axle or whatever, and the flickering of random lights on the dash warning panel...
I'm going to order the ignition switch from RN, replace it, and run it over to dealer for diagnosis...
Thanks Board!
KCD
Old October 14th, 2014, 11:18 AM
Broncoduecer's Avatar
Broncoduecer
peter
D90
You might try rovahfarm for the switch. Lots less then genuine, unless that's what you want.
I'd also get 2 of the special shear bolts that mount the switch. Male Torque head bolts that snap off at the correct installed torque to prevent tampering. QRH100030
And you'll probably cut up the bottom steering lock clamp when trying to make a groove in the bolts to get them out with a screwdriver. I got a new one so it didn't look crappy. QRG100100 or QRG500010
Old October 14th, 2014, 11:34 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Are you sure you need the whole ignition lock & switch assembly ?
The switch is available as a separate item and Trevor at Rovahfarm has Lucas and other brands of the switch too. Also he ships USPS Priority which is much faster than UPS.
Old October 14th, 2014, 01:01 PM
kevincdoyle
Kevin C. Doyle
Talked to Trevor
and sent him both posts to get his thoughts..
Thanks guys!!
------ Follow up post added October 14th, 2014 05:02 PM ------
Thanks Source!
Old October 14th, 2014, 02:42 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I opened up a spare switch that had "failed" and I don't have a clue what fails on these (or what was wrong with my switch). You have a few copper pads permanently mounted on the bottom half and then a pad that floats on the other half with with springs between the case and the pad that provide pressure contact between the two . There is also a spring with a ball bearing to make positive position feels and there is a "wound" spring that you have to turn your key past to start the starter and it returns you to the run position. Before I ever buy a new switch, I will always take a good look at my existing switch to see what went wrong.
There are only a few things I could see going wrong---either a spring or piece of plastic fails (which you would probably be able to feel), one of the contactor-to-connectors works loose, the contacts get dirty, or the case starts to come apart. All of which (with the exception of plastic breaking) would be an easy fix. I cleaned mine up and tossed it in the truck for a quick spare.
Here is an article on that you may find useful if you decide to go this route: http://www.jpurnell.com/rr/repairs/IgnitionSwitch.htm It is from a RRC, so not exact, but similar. These are very easy to take apart--there are three little intents on the case that you carefully pry out. When you press them back in, they make break, but that isn't such a hard fix...
best of luck---
relay
Hood bracket purpose? timtimtj Defender Technical Discussions 1 October 22nd, 2011 04:53 PM
CarFacts! Mispelled on purpose. Can anyone run one for me? D90Overkill Defender Technical Discussions 1 March 25th, 2009 12:51 AM
Misc parts (D1 and gen purpose) Ray_G For Sale - Parts 5 October 5th, 2008 09:11 AM
Engine Dies: Fuel Pump & ECU Relays? jimngo Defender Technical Discussions 4 October 15th, 2006 01:25 PM
fuel pump and relays? steved90 Defender Technical Discussions 5 September 11th, 2006 03:57 PM
