Purge Valve Flow Fault - Defender Source
Old April 2nd, 2013, 07:56 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Fault: 0441
Before I pay $334 (plus labor) for a Charcoal Canister Purge Valve with AEL, anyone have a cheaper solution? I just dropped $1900 in repairs and maintenance last week.
'97 NAS D90 SW
http://www.roverparts.com/Parts/ESR3980G.cfm
Old April 2nd, 2013, 10:45 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Before you drop the $334 you may want to try this.
http://www.amazon.com/Dorman-911-800...=5336118855-20
A guy on LRF patched it in and I bought one did the same. You will want to carefully cut off the tubing from the push-connect fitting on the plenum side. You'll need to reuse this one. Get about 3ft of vacuum tubing and splice it in. Push the vacuum tube on the charcoal canister and run a short length to the new purge valve. Then run a longer piece of vacuum line from the valve to the reused push-connect fitting on the plenum.
The electrical plug is a direct fit with the LR one.
Half of the reviews are from D2 owners, LOL.
Might be worth a try before plunking down serious cash.
Old April 2nd, 2013, 10:49 PM
jafir's Avatar
jafir
Jafir Elkurd
I've got the Hyundai purge valve on my d2, but I actually bought it at Hyundai.
Old April 2nd, 2013, 10:51 PM
Since it shows as a Disco I part, I am sure one of the rover recyclers will have one used much cheaper. Heck, you could almost buy a whole DI for the price of that!
Old April 3rd, 2013, 09:07 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
You can use the D1 part, the only thing different on a Defender is the line.
Old April 3rd, 2013, 10:45 AM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Gents, thanks a bunch for the intel! I'll report back with my final solution.
Old April 22nd, 2013, 11:25 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Resolution: The $21 Kia part worked! Thanks fellas.
Purge Valve The Wizard Defender Technical Discussions 5 September 24th, 2014 05:43 PM
97D90 Purge Valve Replacement ESB Defender Technical Discussions 0 October 19th, 2012 01:05 PM
Code P1179 Purge Valve ? ERICZZ Defender Technical Discussions 3 September 22nd, 2009 04:20 PM
Need Purge Valve for Air Filter Box taoseno Wanted 0 September 10th, 2009 02:27 PM
Purge Valve ESR4222 Hammertime Wanted 0 February 6th, 2009 03:48 PM
