Purge Valve - Defender Source
Old January 8th, 2011, 09:33 PM
The Wizard's Avatar
The Wizard
Douglas Wozny
1994/ Defender 90 #500
Purge Valve
Purge Valve: what is it? Where is it? and how do I fix it from leaking? MY check engine code (88) says Purge Valve leaking.
The Wizard
To paraphase "Oddball" (Donald Sutlerland, "Kelly's Heros", 1970) "I only drive 'em, I don't know how to fix them."
1994 Defender 90 No. 500
Old September 24th, 2014, 03:39 PM
Fred Lobster's Avatar
Fred Lobster
Pete Gerbine, III
1993 110 (#451)
This looks like a pretty old, unanswered, post....but my NAS 110 threw a fault code 88 this morning...so I am searching for solutions...
Old September 24th, 2014, 03:55 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Test P-
Old September 24th, 2014, 04:11 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
If your purge valve is having a problem then your vapor canister is probably saturated and need replacing. The purge valve is built into the canister on a 93-95. Let me guess, you're getting a strong gas smell from under the hood.
Old September 24th, 2014, 05:31 PM
Is the metal tank in the back under the wheel well rusted with a hole in it?
I would check that visually first.
Zack, wrong purge valve! That is for the ABS system which is not on an NAS 110.
Old September 24th, 2014, 05:43 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Why do they use the same damn error code?
Disregard my post, sorry!
Code P1179 Purge Valve ? ERICZZ Defender Technical Discussions 3 September 22nd, 2009 04:20 PM
Need Purge Valve for Air Filter Box taoseno Wanted 0 September 10th, 2009 02:27 PM
Purge Valve ESR4222 Hammertime Wanted 0 February 6th, 2009 03:48 PM
4.6 Valve Cover tbutzow Wanted 2 January 28th, 2005 02:18 AM
Fuel line valve cracking RickM Defender Technical Discussions 2 October 21st, 2004 11:15 PM
