PUMA SW doors: stereo questions - Defender Source
Old November 20th, 2017, 02:46 AM
defender1844
Amit Likhyani
It looks like you can get a 6 or 6.5" speaker low and forward in the door provided you use a spacer. In a setup with power windows and locks has anyone also installed a crossover in the door? I'll have the doors, doors cards, etc in front of me in a couple of weeks once Ash gets done but based on google images searches it does not look like there is much room if you have the window regulator. Anyone with thoughts, pictures or otherwise?
Old November 20th, 2017, 09:46 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
FWIW I have 6.5" in my front doors w/ tweeters and crossovers. I do not have power window or locks though.
Old November 20th, 2017, 09:57 AM
defender1844
Amit Likhyani
Adam, where did you put the crossover and how large is it?
Old November 20th, 2017, 10:56 AM
AdamSanta85
91' D90 200TDI
This is the component system
https://www.jbl.com/car-audio-system...urrent#start=1
From what I remember the crossover is approximately 3" x 6"x 2"
Originally I was going to make a bracket and mount it but it made more sense to just duct tape it to the inside of the door card. Now if I want to remove the door card I just disconnect from one spot on the crossover and it all comes off together with wires still connected to tweeter/speaker. I did this end of last summer so its been over a year now without issue.
Old November 20th, 2017, 11:24 AM
Santini1228's Avatar
Santini1228
Steven Phelps
85/110
Im planning same thing no crossovers but 6.5 on puma door card pwr windows and locks. Found these on ebay they are stackable as well.
On side note my pwr door locks are giving me hell. Changes in temp seem to contract the inner door metal misaligning the linkage. If there is any resistance on the linkage tbe system unlocks all doors. Ive screwed some barstock in the door to try to stiffen it but still plaguing me. Anyone have same issue and a solution.
Old November 20th, 2017, 12:15 PM
defender1844
Amit Likhyani
nice find on the rings. I may need a full 1.5" as the mounting depth on the speakers I'm looking at ranges from 2.75 to 3" and based on what Ash advised me: there is 1.25" to 1.5" between the back of the door card and the regulator motor.
door, puma, stereo
New Style SW Doors bjp Defender Technical Discussions 39 December 26th, 2009 03:04 PM
Switch from ST doors to SW doors TAIIISI Defender Technical Discussions 5 August 29th, 2005 12:27 PM
Stereo Wiring Questions gtg067i Defender Technical Discussions 1 June 19th, 2005 08:10 PM
ST doors an SW rover4x4 Defender Technical Discussions 6 October 6th, 2003 02:29 PM
