Puma seat part question...help!! - Defender Source
Old April 11th, 2015, 05:22 PM
coffee's Avatar
coffee
John Oates
1993 NAS Defender 110 #367/500
First, I'm an idiot. I ordered puma seats and am installing them in a NAS 110. Front seats were a breeze. The 60/40 split seems fairly easy, though I searched and found the video that shows how to accommodate for the difference in wheel well slope in the newer models. The question is that I'm not sure what these parts are. The rectangle bracket is I assume for the wheel well, though as I mentioned, doesn't fit. Any clue where the small piece goes or the l-shaped bar???? I'm so confused. Thanks for your collective wisdom. I'm almost out of beer and still can't figure it out
Old April 11th, 2015, 09:21 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
That little piece in the middle looks like the spacer that slips into the end of your rear crossmember so you don't crush it when you tighten the bolts holding the internal supports for the back hoop. That probably didn't help though, sorry.
Old April 11th, 2015, 09:47 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
I have puma 60/40s and the part on the top of the photo looks a bit like the part that attaches to the sloped portion of the wheel well that the seat rests on. There would be 2 of these. It looks too big though.
The other part is new to me.
You should be able find instructions on line or maybe even a video.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old April 11th, 2015, 11:16 PM
jwb
Jason
1988 110 CSW
Bottom part is AQR710290, the reinforcement bracket for the rear floor latch striker assembly. These brackets attach under the rear cargo floor to the frame.
The other 2 pieces are not for the 60/40, they are for the 3rd row seat belts reinforcements EIO500060 & EIO500070 (the "L" brackets in wheel well to the frame) and KVX000020 (rear x-member spacers as mentioned by one ten).
The brackets that Reese mentioned (AFU710230) are not in your picture. They pop rivet to the wheel well and the rear of each seat rests on top. If you are not modifying the wheel wells with a cut out, then don't rivet these in until you position a spacer under the striker brackets and seat hinges. The work around will make for less reclined seating.
Old April 12th, 2015, 01:04 AM
The part with the tube doesn't fit with a roll cage. The tube part bolts to the rear crossmember in the same place as your under-tub section of the cage. When I installed a cage on my Puma110, I just cut this tube off from the plate. The plate will only fit if you have a puma-style tub with the stepped wheel well boxes. Let me find my thread with pix and you'll get an idea visually.
The first few pix in his thread are the mounting and modification of this part:
http://www.defendersource.com/forum/...all-41001.html
Old April 12th, 2015, 05:41 AM
Reese_D90's Avatar
Reese_D90
Reese
I had 4 plates fabricated for the puma seat mounting points so that I could bolt into the same structure under the rear deck that the NAS seats bolted into. Let me know if you would like a couple of pictures.
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old April 12th, 2015, 06:38 AM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Are you running puma middle row seats without modifying your NAS tub?
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old April 12th, 2015, 08:38 AM
Reese_D90's Avatar
Reese_D90
Reese
I couldn't rationalize modifying the NAS tub. A modification to cut a notch in the angle of the wheel well will allow the seat to set lower in back to improve the angle of the seat back. It's is acceptable without modification but it is pretty upright. I added a few washers to the front legs to get closer the the right angle.
I wanted the upgrade because I have kids that ride in the back and the stock NAS seats have a low back that are not as safe as the puma style.
I kept all the original seats if a future owner wants to take it back to stock.
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old April 12th, 2015, 09:07 AM
lordhelemt's Avatar
lordhelemt
Paul
Can you post pics?
Old April 12th, 2015, 10:14 AM
Reese_D90's Avatar
Reese_D90
Reese
Sure
There is a seat pic in my registry to show the seat angle. I will crawl under the truck to take a few more.
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old April 12th, 2015, 10:22 AM
jwb
Jason
1988 110 CSW
Ruggedguide's video of the basic concept, aside from more robust under body supports like in the original post.
Old April 12th, 2015, 11:13 AM
Reese_D90's Avatar
Reese_D90
Reese
Photos
See attached photos.
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old April 12th, 2015, 11:22 AM
Reese_D90's Avatar
Reese_D90
Reese
Interior shot
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Reese_D90's Avatar
Reese_D90
Reese
Structure with new fab plate. Note the plate has a 90 at the top to accept the top bolts.
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old April 12th, 2015, 11:23 AM
Reese_D90's Avatar
Reese_D90
Reese
Other side
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old April 12th, 2015, 11:24 AM
Reese_D90's Avatar
Reese_D90
Reese
Feet attached on interior
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old April 12th, 2015, 01:18 PM
lordhelemt's Avatar
lordhelemt
Paul
Thanks. Looks like I'll go puma middle row instead of the exmoor high back.
Old April 12th, 2015, 02:24 PM
coffee's Avatar
coffee
John Oates
Thank you - this is really helpful. I got them installed, and just left all the parts off!
------ Follow up post added April 12th, 2015 01:26 PM ------
Yes, I didn't modify the tub. Ideally, I'd like to cut out a portion of the wheel well and fabricate a plate inset to pop rivet into place. I got them in and they are fine, but I had to put spacers under the front legs so that the seats would sit evenly.
------ Follow up post added April 12th, 2015 01:28 PM ------
[QUOTE=Reese_D90;628065]I couldn't rationalize modifying the NAS tub. A modification to cut a notch in the angle of the wheel well will allow the seat to set lower in back to improve the angle of the seat back. It's is acceptable without modification but it is pretty upright. I added a few washers to the front legs to get closer the the right angle.
I kept all the original seats if a future owner wants to take it back to stock.[/QUOTE
that's exactly what I did - and why I did it. I have three young kids and the seats were too low, not to mention no shoulder strap in the middle seat. I'm pretty happy with them. I went with the grey vinyl, which should be awesome on an August afternoon in Austin!
------ Follow up post added April 12th, 2015 01:30 PM ------
Interior shot
nice - that is a better angle than mine. I need to lower the back a little. thanks for all the comments - very helpful. I thought this would be a 3 hours - 8 beer job - it was much more....
Old April 12th, 2015, 02:36 PM
coffee's Avatar
coffee
John Oates
Done and happy
Old April 12th, 2015, 03:22 PM
Reese_D90's Avatar
Reese_D90
Reese
Looks good.
I think every Land Rover job is a one case minimum.
Cheers
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Puma Engine Question Mpigapicha Defender Technical Discussions 10 February 11th, 2015 10:10 AM
Seat part part number needed javelinadave Defender Technical Discussions 16 January 26th, 2015 03:54 PM
Fiberglass TDCI/PUMA bonnets part 2 atlcruiser The Vendors Loft 17 November 26th, 2014 02:45 PM
Help: 60/40 Seat Part Miller Defender Technical Discussions 2 February 17th, 2012 10:37 PM
Bottom Part of Rear Seat Belt "V" OR Part Number? hutch Wanted 5 March 25th, 2008 08:41 PM
