Puma doors help - Defender Source
Old May 2nd, 2016, 09:42 AM
JiriPilot
Jiri Marousek
1986
Puma doors help
Greetings Defender addicts. Question. I have an '86 D90 and got a set of Puma doors for it. Anyone has done that upgrade lately? I saw on a few posts that some did the swap and the striker bold holes for the newer striker needed were already drilled in the door frame. It appears that my truck doesn't have the pre-drilled holes for the newer style striker. Can any of you guys help with location of the holes to drill holes for it? Thanks much!
Old May 2nd, 2016, 12:23 PM
JiriPilot
Jiri Marousek
1986
I guess more specifically. Anyone knows the exact location to drill or could help me out with a trace from where their striker is drilled into the tub / frame?
Old May 3rd, 2016, 12:22 PM
JiriPilot
Jiri Marousek
1986
Anyone? Pleeeeze.
Bump :-)
Old May 3rd, 2016, 03:19 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Couldn't you mount them and see where they hit?
Old May 3rd, 2016, 03:45 PM
JiriPilot
Jiri Marousek
1986
Gave that a swing. But is way imprecise since the closed door covers the sill and it's nearly impossible to align the striker from the inside, let alone mark the location. So wondering if anyone has a layout / distance or even a simple cardboard trace.
Old May 3rd, 2016, 06:59 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Are you saying that your pillars don't have a second set of holes or that the new strikers don't fit the holes on the pillars where the old strikers were mounted? What style handles did your old doors have?
Old May 3rd, 2016, 08:00 PM
JiriPilot
Jiri Marousek
1986
My pillars don't have the doors for he new striker. The old doors are lift lever so the striker is the larger one that bolts lower on the pillar. I am looking for anyone that can help trace and pinpoint the two holes I need to drill higher up for the new style striker. Thanks much!
Old May 3rd, 2016, 08:06 PM
cowboy
steven
http://www.defendersource.com/forum/...tml#post167145
Did you see the above post? I suppose it could mean that the pillars on D's with the pre-Puma push-button doors already have the holes in the right place. Anyone?
Old May 3rd, 2016, 08:31 PM
JiriPilot
Jiri Marousek
1986
Yeah. Mine are the lift lever so unfortunately the holes aren't there. I think NAS and the newer push buttons did have the holes sounds like.
Old May 3rd, 2016, 08:41 PM
cowboy
steven
OK, so, you need intrusive access to a Defender with push button doors.. If you can swing that, maybe pull the strikers & make a template for the holes with tracing paper? Ugh. Or just to go out on a limb, buy a pillar with the right bolt pattern from a wreck somewhere in the world & experiment with making templates until you're convinced that you've perfected your method?
Old May 3rd, 2016, 09:42 PM
JiriPilot
Jiri Marousek
1986
Well. Hoping someone in process of restoration of an NAS or later style truck has a tub being worked over that could trace it. Would actually be good as a PDF to share here since puma door upgrades seem common. I know it would be a PITA to remove the striker from a running truck. Hopefully someone has a tub or is restoring a tuck that is willing to do a quick trace?
door
Defender 90 300tdi HARDTOP /COUNTY CONVERSION with PUMA BONNET - FUJI WHITE /PUMA FROMUK For Sale - Vehicles 17 December 9th, 2015 04:54 PM
TDCI Puma Bulkhead LHD 2015 / Complete Puma Front Doors 110fender For Sale - Parts 10 September 6th, 2015 07:35 PM
Puma ft doors atlcruiser The Vendors Loft 2 March 23rd, 2013 01:47 AM
Pressed doors ( TD5 / Puma ) lock barrel? leastonce Defender Technical Discussions 3 February 8th, 2013 02:27 PM
Puma Hood /Hard Top doors Split Cost to CALI CDeWan Wanted 0 February 11th, 2011 05:05 PM
