Puma Door vs Split Door Road Noise - Defender Source
Old December 4th, 2015, 02:49 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Has anyone who transitioned from older split doors to Puma doors noticed a reduction in road noise? I am about to begin the swap here shortly.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
1971 109 3 Door (Sold)
Old December 4th, 2015, 02:52 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
What condition are the split doors in, my buddy is lookin for a set?
Old December 4th, 2015, 02:58 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
They are actually in great shape. Alpine White. My issue is that I live in Florida and the "sliding glass upper" gets pretty hot and limits my air flow since they only open 1/2 way. I figured a roll up doors opens the entire window area for increased airflow.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old December 4th, 2015, 03:05 PM
JohnsD90's Avatar
JohnsD90
Very cool, I have relayed this too him. I've not ran the same rover with both style doors, but i would be very surprised if there was not an improvement with sound and heat insulation with the puma doors.
Old December 4th, 2015, 03:41 PM
The difference is substantial. Went from NAS split doors to new style roll ups and the difference is obvious. If you are building up the doors, don't forget there is a separate molded foam piece which goes behind the door panels.
Old December 4th, 2015, 04:23 PM
jason1st
Jason Crandall
2006 LR3 2012 SC 1983 110
I just made the switch and am looking forward to driving to see the difference.
Old January 9th, 2016, 06:57 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Follow up: I swapped out my split doors for roll up puma doors. I am happy with the swap. The main reasons are an increased feeling of openness based off the lack of sliding glass framing in my field of view, better air flow, and a more solid feel / less road noise. The only cons I have seen are its harder to lean over and close the other windows if it starts raining, no longer can I just lean over and slide glass. All in all a solid upgrade.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old January 10th, 2016, 06:26 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Funny, I actually want to go the other direction. My dd is a 90SW and I like running with tops off. A 90 is much easier to cool down with AC though. Cooling down a 110 on humid days can't be quick or easy I'm sure.
door
Grinding noise in 5th at 70mph (80kmph) - 2.4 Puma Zone30 Defender Technical Discussions 2 April 21st, 2015 10:38 AM
Needed: 83 split door inner handle assembly Werrea Wanted 13 April 19th, 2015 12:43 PM
Split Top Door cards- set of 4 aosias For Sale - Parts 4 December 2nd, 2013 11:30 AM
Puma Hood /Hard Top doors Split Cost to CALI CDeWan Wanted 0 February 11th, 2011 05:05 PM
Road and Engine noise test - Let's measure Manimal Defender Technical Discussions 23 January 14th, 2010 01:14 PM
