Puma dash upgrade ? - Defender Source
Old October 1st, 2012, 07:31 PM
spartan's Avatar
spartan
Fred
83 D110
Puma dash upgrade ?
Anyone every look into the possibility of upgrading to a Puma dashboard? Not just a simple upgrade but installing a RHD Puma dash on a LHD defender? The gauge console looks like it might be able to moved to the left.
I have emailed a couple of places in the UK and they dont think it can be done. Im tempted to just buy a dash and try it. I want to ask here first to see it anyone has attempted this modification.
Not worried about the gauges since I will be using aftermarket electronics. The engine is a diesel.
Old October 1st, 2012, 07:50 PM
I'm not expert, but I seem to recall that the bulkhead is a bit different too. That's got to be a bit of cash to just throw at an experiment. Even taking that route, I would hold out for a LHD version. I'm sure one will show up in France or Germany eventually if you monitor them.
Old October 1st, 2012, 09:26 PM
Have you looked at any of the posts I've sent in reply to your other posts regarding this? It look like shit (but sort of blends in) and probably still just about as best as you can expect - regardless of whether it's a regular D90 RHD to LHD, TD5 RHD to LHD, or Puma RHD to LHD dash. They'll all require some metal fab, and painted in a color that closely-matches the dash.
Yes, bulkhead is definitely different with the newer-style dashes - more different than the old RHD to LHD bulkhead conversions that have been done.
Old December 23rd, 2012, 11:07 AM
TravelerBT's Avatar
TravelerBT
Philip Marshall
2003 Disco 300TDI
Where can I purchase that Dash??? I would love to pick one of them up for my truck...
How much would the dash replacement kit cost?
Old December 23rd, 2012, 11:41 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
ebay.co.uk
Seen several complete bulkhead / dash combos in the last year. I haver never seen one in person but would think if you had the entire bulkhead / dash the hard part would be getting the wires figured out.
http://www.ebay.co.uk/itm/LAND-ROVER...item3f203e8e3d
Old December 23rd, 2012, 11:45 AM
I love how the puma uses the same indicator stalks from early trucks!
Old December 23rd, 2012, 11:54 AM
looks the same but not plug/harness is different
------ Follow up post added December 23rd, 2012 12:02 PM ------
There is no "metal fab" or paint work required on early bulkheads other than moving the block off plates from one side to the other which is as simple as drilling out a few rivets and reinstalling on the opposite side.
Old December 23rd, 2012, 01:11 PM
Mendicant
I think LHD and RHD dashes start as the same molded part, but then the cutouts are different. Don't forget Puma dashes don't allow for dash vents.
Old December 23rd, 2012, 09:46 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
I have a LHD Puma dash cheap...
I bought the LHD Puma Dash a year or so ago and have one here for $800.
It does not have everything, but is a good start for someone wanting most of the parts to convert at a reasonable price.
RDavisinVA
Old December 24th, 2012, 02:45 PM
FLRover
Richard
So all the bulkheads are the same and this would work with an older RHD truck?
Old December 24th, 2012, 03:01 PM
No, they are not all the same.
Old December 24th, 2012, 03:55 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Would it be simpler (if more expensive) to upgrade to a Puma bulkhead and dash? Are the other fittings the same?
Current fleet: '85 Ninety 3.9 V8i Auto SW,'07 BMW 335Xi.
Old December 24th, 2012, 06:13 PM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
The eBay link that Dave posted is for a Puma bulkhead and dash combo. It ended at 510 ($821.10 at today's rate).
I don't know if that's an average price for this but assuming it is, I wonder how much it would cost to get it stateside? Maybe try to contact Stephen from Safari HP. I know he regularly imports a container full of rover porn.
I also noticed the auction did not include a gauge pod. I wonder how much more that would cost?
Glenn
Old December 24th, 2012, 06:24 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Not sure if that'd be allot of use, as the gauges are canbus... I think. Did read on one of the UK forums the guys upgrading to Puma are just using VDO gauges on a alum dash panel.
From an SA LR site....
Keep the following in mind:
- The Gearlever in Puma is further away from the firewall. (On Puma , Gearbox is further back from the front hence the tranfer case is also located further back. (That's why the Front propshaft is longer than the Td5,Tdi and 2.8i)
- Because of this the Puma Dash (Centre portion) is designed to be further from the firewall (closer to the passengers). - The Puma Cab feel smaller inside)
- Because of the above the gearlever / Transfer case lever of pre-puma could be in the way so that there could be no space to fit the Puma Dash
Old December 24th, 2012, 11:30 PM
Uh no.
------ Follow up post added December 24th, 2012 11:33 PM ------
That ride in in one of my containers ? Man you slip all kinds of crap past me
Old December 25th, 2012, 05:19 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
You my find it difficult getting the guages (especially the temp) to work with any other engine apart from the 2.4/2.2 TDCi, as apparently it runs on a CAN BUS system and not analogue like the V8/Tdi/Td5. someone on the defender2.net forum is/was trying to fathom it out and not getting very far.
But as far as the physical fitting the dash assy into an older bulkhead, I gather it was /fairly/ painless. the heater unit is totally different on the puma dash, it sits in the middle like disco/rangies do, but I'm sure you could graft in the original NAS/euro pre-puma heater with some pipework.
The puma dash is horrible in a truck cab though.... you feel really cramped. a hard top with the bulkhead in place (so the seat won't go back very far) isn't much better either... my knee hits the edge of the dash when I drive one. although i am tall.
Old December 25th, 2012, 05:35 AM
Chris B
72 + D1 drivetrain =?
If you really want a RHD Puma check the UK salvage dealers and buy a complete parts in BH
Old December 25th, 2012, 06:04 AM
maleger
Marc-Andre Leger
I tried some salvage dealer in France and they had some LHD pum dashes for sale. What stopped me was the issue with the air vents.
Old January 8th, 2013, 12:16 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Quite a few useful pic's in this rebuild thread if your thinking of installing a Puma dash - http://www.aulro.com/afvb/projects-t...a-project.html
Old September 16th, 2016, 09:41 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Thread bump & question- would the Puma dash work with the LS engine? I was going to put the Dakota Digital display in, but if the GM 'brain' will 'talk' to the Puma dials, I might go that route...
dash
LHD Dash CDeWan For Sale - Parts 32 October 3rd, 2012 05:03 PM
anyone have any exp with this dash upgrade? trislerjw Misc. Chit-Chat 36 April 22nd, 2010 03:34 PM
Dash Rotted Out, Had to Fix It JimC Misc. Chit-Chat 7 February 6th, 2009 03:20 PM
New Defender Dash parts TDI Guy For Sale - Parts 1 April 3rd, 2005 10:58 AM
1997 Dash panel - what's there? ronward Defender Technical Discussions 6 April 26th, 2004 05:47 PM
