Puma dash questions... - Defender Source
Old January 21st, 2018, 09:52 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
What are the part numbers for the blanking plates to cover the holes where switches are removed? I don’t have electric windows, so those will need to be removed- plus others. I’d also like to find out if there’s a ‘hardware kit’ with all the necessary screws, nuts & bolts to install one, plus I need the two screws/bolts that hold the grab handle on. I also need the following parts- one square under dash cover, a speaker cover & trim ring, and the black bit on the heater core thermostat (I think that’s what it is). I’ll also have the following for sale soon if anyone is interested- Puma Diesel binnacle (says ‘Diesel’ on the fuel gauge & has a 6k tach) plus the side-mount accessory switch console and a single DIN centre fascia without swiches or clock.
Paul.
ID:	348065   Click image for larger version
Current fleet: '85 Ninety 3.9 V8i Auto SW,'07 BMW 335Xi.
Old January 21st, 2018, 09:57 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Here’s the single DIN fascia with the switches. I’ll also need a couple of auxiliary switches for lights. Prefer to have them at the top.
Old January 21st, 2018, 01:15 PM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
Grab bar screws- https://www.landroverworkshop.com/parts/FYG500050
Then click Facia diagram at bottom of linked page. Some items there.
Do the blanks you have already have PNs on back, maybe?
KGH - “Stinky LR diesel” Defender Snob
Old January 21st, 2018, 01:25 PM
mgrgpg
Mark
1989 D110
I will have the window switch blank inserts available soon. My doors will have electric windows and my current fascia has the blanks in them now.
Old January 21st, 2018, 03:48 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Do you want my window switches? We can trade straight across if you like? I have both left & right.
dash, puma
Puma Dash Tweeter / Speaker Size mgrgpg Defender Technical Discussions 1 November 28th, 2017 04:40 AM
Puma dash Double DIN stereos that fit??? EC808 Truck Build-up's & Restores 4 July 9th, 2017 09:29 PM
Puma dash upgrade ? spartan Defender Technical Discussions 28 October 12th, 2016 12:39 AM
Puma LHD Dash for Sale rdavisinva For Sale - Parts 9 June 1st, 2015 04:30 PM
LHD Dash CDeWan For Sale - Parts 32 October 3rd, 2012 05:03 PM
