Pulling my hair out with handling issue - Page 2 - Defender Source
Old February 19th, 2010, 08:56 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I would check the rear links and a-arm bushings. Also, have a shop do the alignment.. Leave that stuff to a shop. Where in NY are you. I have a great place in Maywood NJ for that.. He has done plenty of d-90's
Is there any strange noises? knocking?
Legend in My Own Mind.
Old February 19th, 2010, 09:55 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I have a slight veer when I get on/off the gas--it has plagued me for years but not serious enough to replace any of my A-arm components which are the only thing I have not replaced (and which all seem tight and good, even with a bar prying on them to check for play). That said, I am running a detroit in back and tru-track in front and I am thinking when I get on/off the gas, the lockers in that situation bias power to one axle shaft which may certainly explain it.
That said, I would check both your diffs and see if you possibly have a broken axle shaft or bad diff--that would certainly have some of the symptoms you are referring to. Assuming all your suspension bushing are in OK situation, this or the a-arm is the only thing that makes sense to me. I don't see this as being a pre-load swivel issue but that is worth checking for maintenance sake.
Old February 19th, 2010, 10:03 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Rear link bushings at the chassis??
Pulling a Trailer/RV michael15 Defender Technical Discussions 18 February 27th, 2006 07:47 AM
Clutch issue? Help with diagnosis..... Hans Defender Technical Discussions 13 December 18th, 2005 05:19 PM
strange heat issue jabber Defender Technical Discussions 15 March 6th, 2005 05:42 PM
Driveshaft Issues Continue...?? P1CR Defender Technical Discussions 9 July 22nd, 2004 09:12 PM
