Pull out your wet carpet vs drying in the truck - Defender Source
Old February 1st, 2016, 11:46 AM
signalMTB's Avatar
signalMTB
Rusty
'97 NAS D90 / '94 RRC / '05 L322
I'm tracing a leak and thought only the carpet by the rear right door was wet. I lifted up the carpet in the boot and it was soaking wet. Even after a full night in the garage draining with a fan on it, the carpet padding is still wet. So best pull it out to dry rather than dry in the truck. This padding is just a big sponge. Thinking maybe leaving it out and just go back to rubber mats to prevent unseen water rusting.
'05 RR L322 HSE
'94 RRC LWB
'97 NAS D90
many others that have sold
Instagram: @SecondDailyClassics
Old February 1st, 2016, 11:47 AM
signalMTB's Avatar
signalMTB
Rusty
Carpet
'05 RR L322 HSE
'94 RRC LWB
'97 NAS D90
Old February 1st, 2016, 12:06 PM
Remove its a giant mold experiment.
Add dehumidifier
Old February 1st, 2016, 12:28 PM
87 D110 (Ruby)
The stuff in the Rangies is awesome for two things:
1. Sound deadening...best their is at it
2. Water retention to promote rust....best their is at it
Old February 1st, 2016, 06:47 PM
that stuff is evil, if i could find a better alternative for mitigation noise and heat I would be all for it. That insulation is the devil! Range Rover Classics leak as bad as Defenders.
Old February 2nd, 2016, 07:24 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Where are the leaks coming from?
Old February 2nd, 2016, 07:29 AM
phoenix37's Avatar
phoenix37
john
terrible sponges.... replaced mine with closed cell foam.
OverKill Pro™ 9 sq. ft - 1 sheet - Second Skin Audio
Old February 2nd, 2016, 08:26 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Just as bad as the insulation in Discos. Its hard on top and foam on the bottom. So if it gets wet it will never dry.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old February 2nd, 2016, 11:07 AM
signalMTB's Avatar
signalMTB
Rusty
not sure yet...I just dropped the truck off at the weld shop to get one of the rear seat belt anchor points re-welded. I know some water was coming in from that seam, but the pads were too wet and on the wrong side for that to be the issue. It's got to be either 1.) seal around arch/door 2.) rear hatch that I have since replaced and/or 3.) sunroof drain line (assuming it has one of course).
'05 RR L322 HSE
'94 RRC LWB
'97 NAS D90
Old February 2nd, 2016, 11:10 AM
signalMTB's Avatar
signalMTB
Rusty
The rusted anchor point
'05 RR L322 HSE
'94 RRC LWB
'97 NAS D90
Old February 2nd, 2016, 12:47 PM
signalMTB's Avatar
signalMTB
Rusty
3 days and still counting...just checked on it in the garage under the steady fan and parts of it still spongy wet. unbelievable. 65 degrees here too.
'05 RR L322 HSE
'94 RRC LWB
'97 NAS D90
Old February 2nd, 2016, 12:52 PM
Don't close the garage doors the moisture need to escape. If you want to get rid of the moisture in a closed space use a dehumidifier.
Once dry you'll need to use a biocide to stop mold formation.
Old February 2nd, 2016, 08:08 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I hate Carpet pads that are sponges or open cell. Get rid of them imho. If applied on rubber mats, just rip it all off and add something like dynamat. You still need to check for trapped moisture between rubber and floor, but not have it keep the way it does. My floor is rubber restaurant mats, with big holes. Moisture escapes easily (but my truck is not meant to be "finished", just used. Makes it more fun for our family's frolicks).
Old February 3rd, 2016, 03:07 PM
signalMTB's Avatar
signalMTB
Rusty
Got the anchor point welded. Getting a new headliner now and will check the drain lines.
'05 RR L322 HSE
'94 RRC LWB
'97 NAS D90
Old February 3rd, 2016, 03:15 PM
Do those anchor points tie into the frame or anything else substantial?
x2 for the dehumidifier
Old February 3rd, 2016, 03:23 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
No- they are held in by iron oxide!
Rent my
Old February 3rd, 2016, 03:27 PM
signalMTB's Avatar
signalMTB
Rusty
Underside weld
'05 RR L322 HSE
'94 RRC LWB
'97 NAS D90
Old February 3rd, 2016, 03:31 PM
signalMTB's Avatar
signalMTB
Rusty
Nomar is right! But not mine anymore! Guys did a good job cutting out the old and reinforcing with a plate. Sealed the underside with rubberized coating.
She sat out last night in the rain and no water was inside, so now I'm baffled (unless for some crazy reason they stored it inside but I highly doubt that my 22 year old Rover would get that sort of priority treatment.) Will know more once it comes back from the headliner shop, he's going to do some leak tests I hope.
'05 RR L322 HSE
'94 RRC LWB
'97 NAS D90
Old February 3rd, 2016, 07:18 PM
el nino and global warming
Old February 19th, 2016, 08:48 AM
signalMTB's Avatar
signalMTB
Rusty
water tested today and appears to be coming in from the door seals, particularly at the top...they're in pretty bad shape so looking to replace, of course they're not cheap though.
'05 RR L322 HSE
'94 RRC LWB
'97 NAS D90
left pull when braking paulb Defender Technical Discussions 19 November 7th, 2017 09:21 PM
Starting issues - Truck wont Fire/Catch (Wet?) sad_story Defender Technical Discussions 63 November 15th, 2015 11:04 AM
built a pull-out bed out of workshop scrap trailer guy Smaller Projects 14 December 13th, 2014 12:21 PM
Can I pull wire harness out Campbell Defender Technical Discussions 4 February 21st, 2010 09:20 AM
genuine carpet out of a 95 sw mattdh For Sale - Parts 7 April 10th, 2005 01:06 PM
