PS Fluid Compatibility - Defender Source
Old June 23rd, 2011, 10:22 AM
Rugbier's Avatar
Rugbier
Gustavo
I am replacing with new items my Steering box, Pump and hoses.
What PS Fluid could I use besides the non locally available Pentosin CHF 11S - 1 ?
NO SIGNATURE
Old June 23rd, 2011, 01:08 PM
I just use ATF
Originally Posted by pendy
I'm here for the D's
Old June 23rd, 2011, 01:47 PM
Rover calls for dextron/mercon ATF. I use the cheap stuff as it leaks out anyway. Make sure to bleed it properly.
Old June 23rd, 2011, 01:55 PM
The Dro
Dro
1988 Ninety
IMSMR if you use PS fluid you will ruin the system... you need ATF
I use Valvoline DEXRON III / MERCON
Old June 23rd, 2011, 05:22 PM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
Just replaced all of my hoses. I recall LR specifies ATF Type F for 93-95 Defenders in the WorkShop Manual. I found out Type F is an old formulation and not to many places carry it anymore.
Old June 23rd, 2011, 05:46 PM
Really? Type F was for manual gearboxes.
Old June 23rd, 2011, 06:04 PM
NoVaKevin
Kevin
sold#1469
i just use cheap ATF for power steering. prefer not to mix different types, so flush and stick with the same. hasnt land rover changed some recommended fluids in the workshop manual over the years?
is type f sufficient for an r380? i know everone on here recommends redline mtl. sorry to hijack.
Old June 23rd, 2011, 06:06 PM
Att and Lucas
Old June 23rd, 2011, 06:08 PM
budzny
Real4X4
NAS 97 ST/NAS 93 110/62
Birthday Committee Team
castrol gt lma or any that exceeds dot 3/4 requirements.
sal
Old June 23rd, 2011, 07:08 PM
Rugbier's Avatar
Rugbier
Gustavo
sal
Sal
I thought Castrol gt lma is for the clutch / brakes
------ Follow up post added June 23rd, 2011 07:09 PM ------
It is all new stuff, new pump, new box and new hoses
bleed? from the box screw?
NO SIGNATURE
Old June 23rd, 2011, 09:16 PM
There should be a bleeder valve on the steering gearbox.
Old June 23rd, 2011, 09:36 PM
budzny
Real4X4
[QUOTE=Rugbier;288184]Sal
Sorry, Sleep deprived! I mean any cheap dextron III tranny fluid will do.
Sal
Old June 23rd, 2011, 10:12 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
You can use whatever you want in a Rover. You can't make the steering any worse.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old June 24th, 2011, 12:34 AM
Sal
Yup. It can be a PITA.
Old June 24th, 2011, 01:58 PM
Crash303's Avatar
Crash303
Josh Harris
97/ D90 ST #1190
Mr goodwrench power steering fluid is a mineral base fluid doesn't break down in high heat/heavy use situations. Plus ATF over time makes the seals become rock hard and crumble and make things start to leak.
When the F*%# did we get Ice cream!!!
"They are, in factory original condition, noisy, they leak water in from the top and oil out from underneath, you can never demist the windows in winter, they handle like scaffolding towers, and use more fuel than Beijing." Richard Hammond
Old June 26th, 2011, 11:19 PM
Rocketman's Avatar
Rocketman
Scott Y
Like I mentioned, I just replaced all of my 95 NAS D90 Power Steering hoses and replaced the fluid. Here is the page from the early 1993 version of the LR WSM.
The recommendation for the Power Steering Fluid is ATF Type F.
File Type: pdf Defender Lubricant recomendations from WSM.pdf (123.2 KB, 76 views)
Old March 26th, 2012, 12:19 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I just noticed a leak and that my power steering fluid is almost empty. Plan to drain and refill. What to refill with? All the above suggestions have just made me more confused. ATF Type F? Redline ATF D2? Does ATF really affect the gaskets?
Old March 26th, 2012, 03:09 PM
Just use ATF (does not matter what kind) and top it up. No need to drain and refill. Where is the leak? Box, lines?
Old March 26th, 2012, 03:17 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I think/hope it's just the hose clamp. Tightened it up and keeping an eye on it.
No clue what is in here already. Is it bad to mix?
Old March 26th, 2012, 03:25 PM
I can't see why as long as you stick to ATF. The LWB has had every type of ATF in it in the 10 years it has been leaking.
Gear fluid ..... Rover- Girl Defender Technical Discussions 3 October 9th, 2005 05:25 PM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
ZF fluid level goes up and down 48vphantom Defender Technical Discussions 4 March 20th, 2005 01:42 PM
