PS Fluid Compatibility - Page 2 - Defender Source
Old March 26th, 2012, 08:36 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Dang, 11 years now & mine isn't leaking. What do you think is wrong ?
Old March 26th, 2012, 10:21 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Me?
Hopefully just a loose hose clamp. I don't think it has leaked after I tightened it. It was almost empty though. Not good.
I bought Valvoline ATF Dextron Mextron for it. I'm contemplating draining it and refilling since I have no idea what is in there (I've never refilled it) nor how old it is.
Old March 26th, 2012, 10:33 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Why not use power steering fluid from local store?
Old March 26th, 2012, 10:43 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Land Rover recommends ATF Dextron IID. I'd go with that or whatever the more experienced on this board recommends.
Old March 27th, 2012, 02:34 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Install a transmission cooler in line. It will prolong the life of your new steering box. Heat breaks them down.
Old March 28th, 2012, 12:27 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Can I bleed the system without starting it up? Workshop manual says not to start the vehicle if its below the dipstick... which it currently is. How hard is it to bleed it? I would like to start fresh but not sure if its worth the effort.
Gear fluid ..... Rover- Girl Defender Technical Discussions 3 October 9th, 2005 05:25 PM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
ZF fluid level goes up and down 48vphantom Defender Technical Discussions 4 March 20th, 2005 01:42 PM
