PS Box rigid lines - Defender Source
Old February 8th, 2011, 10:59 AM
Naplm00
Matthew
PS Box rigid lines
My 1983 110 RD PS box is leaking from the rigid lines with flare nuts that connect to hoses to the reservoir and the feed line.
Are these lines single flare or bubble flare? Also can i just buy a appropriate sized brake line with nuts, cut it into 2 parts and clamp on a new set of hoses?
Its a slow leak, but imtrying to get this truck as tight as possible.
Old February 8th, 2011, 11:06 AM
Naplm00
Matthew
here is apic stolen from another site, im leaking from above the red wire/hose on the bottom of the pic on the right hand side of the PS box.
Thoes two fittings
Old February 8th, 2011, 11:14 AM
have you tried to tighten the fitting?
where exactly is the leak coming from?
the flares are different from brake lines. You can take your lines to a hydraulic shop and have them redone with new hose. In a roadside situation I have used a cut and bent PS line from a chevy pickup for the return line to the reservoir. The fitting thread and flare style was identical.
Old February 8th, 2011, 11:19 AM
Naplm00
Matthew
Yea they are snug. I.m getting leaking from the inside diameter of the flare nut that the rigid line passes through.
The hoses arent leaking, just the connection point. I figued that they had been apart a few times and the flare has been crimped to the point that it no longer seals.
I was hoping it was a sinlge flare, double flare or bubble flare but I guess not.
Old February 8th, 2011, 11:20 AM
Naplm00
Matthew
flare pics
Old February 8th, 2011, 11:31 AM
yeah I know what brake line flares look like. Trust me the PS stuff is entirely different. The do use an o-ring which may be bad on yours.
Originally Posted by Naplm00 View Post
flare pics
Old February 8th, 2011, 11:33 AM
Naplm00
Matthew
Ah ok, that is most likely the issue. Thanks for the help
Who's done a reseal kit in a PS box? Hans Defender Technical Discussions 1 July 5th, 2010 09:12 PM
Passenger Seat Box gtg067i Defender Technical Discussions 13 August 4th, 2009 09:26 AM
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
Waterproofing speaker box? Helihntr Defender Technical Discussions 9 May 26th, 2005 12:31 PM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
