PS box replacement - Defender Source
Old January 21st, 2007, 11:54 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
PS box replacement
I have changed the steering box before but I just wanted to put my self out there for any pointers to make the process easier.
Last tiem I followed the LR manual but centering the steering was kind of a PITA. any pointers around getting it back in right the first time?
Old January 21st, 2007, 12:19 PM
Tim Scully's Avatar
Tim Scully
Tim Scully
95 D90 SW/ 95 RR LWB
Getting the wheel to be right the first time was always hard when I was a tech with the LR dealer I worked for. I found that if you make sure the dowl hole lined up with the gap in the pitman arm it is the center of the steering box's movement( m8x1.25 bolt???). I would try to get everything unbolted with the wheels pointed straight ahead and the steering wheel straight. If you keep the wheels on the ground and the steering wheel is straight the only adjustment you might have to make is the drag link hooking up with the pitman arm. I also always tried to loosen the drag link and make sure I could adjust it before I took everything apart, this made adjusting it easyier later.
Hope that helps and good luck. I also found it easies to bleed the system by filling the system, cranking the vehicle, letting it run for about 30 seconds, shutting it off, then opening the bleeder screw on the box to allow the air in the box to escape. Then I would go through the bleeding process where you crank it and turn the wheel.
ac
Battery Box Replacement? IPSC_GUY Defender Technical Discussions 12 December 23rd, 2009 09:16 AM
Passenger Seat Box gtg067i Defender Technical Discussions 13 August 4th, 2009 09:26 AM
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
Waterproofing speaker box? Helihntr Defender Technical Discussions 9 May 26th, 2005 12:31 PM
