Protection against rust? - Defender Source
Old May 11th, 2013, 07:22 PM
30A's Avatar
30A
Mike Ragsdale
1986 Defender 90
We live on the water in Florida, so things tend to rust rather quickly here. I realize that our D90's exterior is mostly aluminum, but i'm sure lots of stuff under the hood etc are prone to rust without proper care.
Does anyone have advice for the best possible steps that we can take to safeguard against rust? (and how often we should take them)
thanks in advance for any pointers!
Old May 11th, 2013, 07:48 PM
Grover's Avatar
Grover
Waxoyl. Hard wax for exterior ( frame and other steel components underneath)
and 120-4 in cavities, inside frame and bulkhead.
For repairs, use Antiseize on fasteners.
Replace non-load bearing bolts with ss
After playing on the beach, give her a bath...
Good luck...
Cheers...
Old May 11th, 2013, 08:09 PM
30A's Avatar
30A
Mike Ragsdale
1986 Defender 90
Thank you, Mike! Any advice regarding often should I apply Waxoyl, hard wax on the exterior and 120-4 in cavities, etc.?
I already had Waxoyl applied, but I'm not clear on how long that kind of treatment lasts....
Old May 11th, 2013, 08:39 PM
Also spray waxoyl in the bulkhead and hardwax on the underside where stones get kicked up through the hole in the bottom of the inner fender.
Old May 15th, 2013, 02:47 PM
Premoto1
Tyler
1997 D90 SW
Waxoyl is a good idea. I also heard that someone with 300k miles on his D90 installed marine application sacrificial anodes to the frame. He felt this slowed/prevented rust significantly.
Old May 15th, 2013, 04:22 PM
Grover's Avatar
Grover
I had a "Counter Act" system on my old Jeep, seemed to work well.
I also use a industrial wax that is very thin when strayed then dries into a pliable film. I use this in seams, it will wick into the tightes areas, better than the 120-4.
I have used this with success for years on all my vehicles.
Old May 16th, 2013, 12:14 AM
eXtraDutyDisco's Avatar
eXtraDutyDisco
Joey Boerner
1997 Discovery XD
That is a sweet picture.
Rust Management loykd Defender Technical Discussions 44 February 5th, 2010 11:00 PM
Electronic Rust Protection Michael Defender Technical Discussions 31 August 15th, 2007 07:23 AM
Rust? mlw911 Defender Technical Discussions 6 May 24th, 2004 03:48 PM
