Propshaft U Joints - Defender Source
Old August 2nd, 2015, 12:23 PM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
Propshaft U Joints
I'm having quite the adventure finding proper u joints. At first I bought Meyle u joints, but they were made in China so they went back. So then I ordered Hardy Spicer u joints from lrdirect.com (https://www.lrdirect.com/TVC100010-s...rdyspicer.html), which according to the description are branded Hardy Spicer supplied by Allmakes. But when I opened the package I was greeted by blue Britpart boxes... lovely. On the u joint it says "HSL" and "13.11." Who makes them? Is HSL a company? Are they an OEM supplier for LR? And would you use them?
Old August 2nd, 2015, 01:52 PM
Chip's Avatar
Chip
Andrew
Okay so after searching online I guess HSL means Hardy Spicer Limited as per this thread: https://www.landyzone.co.uk/land-rov...dities.283983/. I've only seen the GKN ones online which appear to be made in the EU. It looks like Hardy Spicer is an India based company so that's where these must be made. In any case I guess these are the OEM u joints so I shouldn't be upset then.
Old August 2nd, 2015, 01:56 PM
Yah. If you want the GKN ones, use TVC100010GKN as the part number.
I seem to find they last better. I assume do to better seals. Look like this http://www.roverparts.com/Parts/TVC100010
Old August 2nd, 2015, 02:03 PM
Chip's Avatar
Chip
Andrew
Okay thanks. I guess I'll just use these though since I have them. Hopefully they'll be fine.
Old August 2nd, 2015, 02:22 PM
IME, life depends on how you use them. Mine always die after a day of driving them through mud and streams. On the road, they should last forever. The big rubber seals on the GKN ones seem to keep the mud out better.
Old August 2nd, 2015, 02:45 PM
Hardy spicer is a name I knew from time I was a kid.
All the email addresses on their website go to Dana.com
Assume it's a Dana company
It gets more interesting or confusing....
http://www.landroverexpedition.com/a...t-differences/
Old August 2nd, 2015, 03:03 PM
Dana and Spicer are the same company and have been since the beginning. It is more a question of which brand of their joints are made to what specs and how well. These mass agglomerations of companies make it very hard to know what is what. Sometimes the old company keeps making stuff to the same levels, sometimes the brand name is stripped and farmed off to god knows where.
Dana Holding Corporation
Anywho. I've bought new Hardy Spicer driveshafts in the past and I usually kill the joints in a year or two. Keeping in mind, I drive a lot of mud and water. I always replace them with the GKN ones and they don't seem to die. My experience on my truck. Your may vary.
Old August 2nd, 2015, 03:51 PM
Departing90
Sasha
95 D90
Curious if you've ever used synthetic marine grease on the u joints and what your experience was in mud / water?
Old August 3rd, 2015, 05:45 AM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
Bear in mind the genuine GKN TVC100010 joint uses an oversized trunnion and needles, equivalent to a 1310 Spicer joint in a 1300 size uni.
The Hardy Spicer Australia part number equivalent is K5-A757, the standard 1300 series is K5-LR4. Not sure if/how they correspond to NA part numbers ?
I use the GKN version as, like John I've found they last, and I get them for an excellent price from a local importer/wholesaler.
(I pinched the photo's from an old thread on LR4x4)
ID:	126319   Click image for larger version
Old August 4th, 2015, 06:27 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
WorldPac sells GKN u-joints here in the US. Any shop or distributor affiliated with them can order them. If you can't find a local distributor to order them from, I can get them and ship them to you.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old August 4th, 2015, 06:50 PM
I seem to find they last better. I assume do to better seals. Look like this Land Rover Universal Joint - Propeller Shaft (Same Fit As Genuine Part # TVC100010)
Where are you sourcing the GKN's here in North America? AB or do you have another supplier?
Old August 4th, 2015, 07:42 PM
I buy from the UK, wholesale. Much cheaper than any North American source. In general, shipping is cheaper and much quicker when buying things in the UK than the USA for Canadians.
Buying things in Canada is fairly rare as the retailers here have stupid markups.
Old August 4th, 2015, 09:34 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
RovahFarm for all your new Land Rover Parts and Accessories
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Rear D90 propshaft (driveshaft) mightymo Defender Technical Discussions 4 May 15th, 2012 12:29 AM
Rear propshaft options for 1983 110 mcoleman762 Defender Technical Discussions 17 September 30th, 2010 06:09 PM
Propshaft Gators Overlander Defender Technical Discussions 3 July 6th, 2009 12:30 PM
Front propshaft U-joint ... Retrofit Defender Technical Discussions 8 June 29th, 2008 07:10 PM
D110 Rear Propshaft kjj0506 For Sale - Parts 0 June 6th, 2008 01:36 PM
