Propshaft sizing - Defender Source
Old August 2nd, 2015, 07:34 PM
ionfender's Avatar
ionfender
IO
94 NAS D90, #1379 (SOLD)
Propshaft sizing
My NAS 90 currently has a 3 or 4 inch lift on it, and I'm planning to reduce the lift to 1.5 inches.
How do I ensure I have propshafts that are the proper length to accept the new 1.5 inch lift? And what length propshafts came stock on the 90s? From what I understand the OEM shaft length "typically" will work up to 2 inches of lift.
I'm assuming I'll need to buy different shafts, just want to start to figure the correct pieces I'm going to need for this project.
Thanks.
Old August 2nd, 2015, 08:21 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Give Tom Woods a call, might as well upgrade to 1310 UJ's whilst your at it
Old August 2nd, 2015, 08:23 PM
Just get a stock OEM shaft. They are cheap.
Old August 2nd, 2015, 08:26 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
This. First confirm what you have in the truck, though. Without knowing the history of the truck you may or may not still have stock shafts.
Old August 2nd, 2015, 09:51 PM
ionfender's Avatar
ionfender
IO
Sounds good. OEM and cheap...that makes it easy.
Fish- Definitely aftermarket shafts. Front is a DC from GBR. The rear is a company I don't recognize...Driveline Incorporated with a 949 area code.
Old August 2nd, 2015, 10:26 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Is the rear a DC? Let me know if you're looking to sell or partial swap for OEM shafts.
Old August 2nd, 2015, 10:30 PM
at the risk of pissing off brett, you can still run the dc rear shaft on the lowered truck.
the only thing that matters on the rear is pinion angle. driveshaft length matters, but the difference between a 4 inch lift and a 1.5" lift is negligible.
Old August 2nd, 2015, 10:40 PM
ionfender's Avatar
ionfender
IO
Negative on the rear. Just a DC in the front.
I will be looking to sell/swap the existing shafts. I'm still a few months away though. This is probably going to be a winter project when I'm holed up in the garage watching snow fly.
Old August 3rd, 2015, 05:53 AM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
You might be worrying over nothing, check the plunge on the existing shafts before ditching them.
I don't have a huge lift on the 130, (it's settled to 100mm between the bump stops) but the front has a lot more droop than stock and the front TW shaft is basically what Tom supplies for most all Disco I/II's, RRC's and Deefers dimensionally except for a Defender specific t/case flange PCD.
Old August 3rd, 2015, 06:17 AM
Make the change then see how it drives. If fine problem solved. If not you'll know which one needs fixing
Old August 3rd, 2015, 08:15 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
You can see if they are too long (I think that's your concern) by disconnecting a propshaft at the diff, fully compress it and, while holding it in the same plane as the gearbox output, drop a plumb bob from the front flange of the shaft and see how far back it is from the diff input flange.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
video on proper wire sizing, fuse protecion and grommets silvercreekmotors Truck Build-up's & Restores 3 October 13th, 2013 07:51 AM
yakima megawarrior sizing chirider Defender Technical Discussions 5 March 12th, 2013 10:40 AM
Propshaft Gators Overlander Defender Technical Discussions 3 July 6th, 2009 12:30 PM
Front propshaft U-joint ... Retrofit Defender Technical Discussions 8 June 29th, 2008 07:10 PM
D110 Rear Propshaft kjj0506 For Sale - Parts 0 June 6th, 2008 01:36 PM
