PropShaft bolt spinning at Handbrake Drum - Defender Source
Old December 18th, 2013, 12:28 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
So I went to remove the rear prop shaft and found that a bolt connecting it to the handbrake drum would spin like it was stripped. Is there a workaround to this or am I just retarded?
Old December 18th, 2013, 02:29 AM
Pretty sure you are screwed.
Old December 18th, 2013, 03:49 AM
What a nut job!
Old December 18th, 2013, 08:35 AM
It means the head of the bolt is rounded inside the drum. This happened to me a few times. I seem to recall that copious use of heat and then prying behind the driveshaft flange (to put tensile load on the underside of the bolt head) allowed me to get the nut off without resorting to extreme measures. Failing that, you could always use cutting discs, dremel, or oxy acetylene to solve the problem.
Old December 18th, 2013, 08:56 AM
Dee-stroy the nut. I drilled and chiseled last time this happened. Now instead of just taking off the prop shaft, you get to redo the hand brake and the output flange seal! Yay!
Old December 18th, 2013, 09:14 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Thanks for the tips and levity. . I also stripped a knuckle to hub bolt last night on the LR3 so it was just another typical Rover day.
First time taking this apart so I didnt know what to expect. I have new shoes for the brake; guess Ill order new bolts and a complete in/output seal kit with flanges for the TCase since its leakin. STC3433 an STC3432
loose rear drive shaft bolt at the brake drum tomaco1 Defender Technical Discussions 7 April 13th, 2011 03:19 AM
Steering stop bolt wanted jorge Wanted 10 December 16th, 2005 05:24 PM
ss bolt kit installation question geneseemtn Defender Technical Discussions 2 December 4th, 2005 12:28 PM
Bolt attachment for a Southdown steering guard paulb Defender Technical Discussions 3 January 20th, 2005 08:42 PM
