proper shock mounting - Defender Source
Old April 4th, 2014, 01:25 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
Took apart my front coil spring assembly. Previous owner mounted shock assembly in the manner of Fig A, where the coil spring mounting plate bolts are pinning one of the shock washers down.
Would mounting the new shocks like Fig B result in rattling or suspension noise because the shock disc isn't seated flat on the mounting plate? In Fig B the plate bolts would be underneath the cushioning washer (or at least overlapped).
ID:	92379   Click image for larger version
Old April 4th, 2014, 01:29 PM
DBrands's Avatar
DBrands
David Brandson
D90 Truckcab
Go with B. There won't be rattling if your shocks/bushings aren't blown.
Old April 4th, 2014, 01:40 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
I didn't think you even needed those little washers.
Old April 4th, 2014, 02:15 PM
CaptMidnite
Daniel Choi
Yes, I took a 2nd look at the problem and thought why not use smaller diameter washers or just not use them.
mount
Shock mounting flippedrover Defender Technical Discussions 10 November 19th, 2008 11:36 PM
Proper AC Grill panel (extended for AC) SafariHP For Sale - Parts 0 February 15th, 2008 10:26 PM
15 inch Steelies w/ proper backspacing for my D90 weissbrewer Wanted 6 August 5th, 2007 12:43 PM
Tdi proper startup after oil cooler lines replaced artm Defender Technical Discussions 5 August 7th, 2006 11:59 PM
Proper waterpump torque? cgalpin Defender Technical Discussions 11 April 17th, 2005 09:45 PM
