Proper height for 110? - Defender Source
Old March 20th, 2014, 04:04 PM
Axel's Avatar
Axel
jack
1987 Defender 110 5-door
Is there some standard way to know exactly how high a 110 will sit with stock OEM springs? Mine are sagging. Is there some easy way to know exactly how high one will set with new OEM springs? Like, inches from the ground to the top of the roof or to the wheel well opening, for example? I know they all vary a little bit.
Old March 20th, 2014, 11:24 PM
C391HAT's Avatar
C391HAT
Zach
86 110
There's this:
but using the ground as one point in your measurement does not factor in different sized tires.
What I used to determine the lift I had (or sag in the case of my front springs) is this:http://forums.lr4x4.com/index.php?sh...12#entry437086
The best way to measure your lift is to measure your spring heights with the
vehicle parked on level ground,measure from top to bottom of the rear of the
front spring,and the same for the rear spring,with quality springs you will
find that the drivers side is always slightly taller
STD 90/110 FRONT SPRING measures 260mm +/- 5 mm
The REAR SPRING should be around 300 mm +/- 10mm
Old March 21st, 2014, 10:40 AM
Axel's Avatar
Axel
jack
Perfect. Thank you Sir Zach
110, ht
WTB: Stock Height D110 Springs (4) Lesandjes Wanted 1 October 9th, 2012 08:25 AM
ST with 2" Lift- Need Overall Height Wolf Fabrication Defender Technical Discussions 8 March 19th, 2008 08:04 AM
Need overall height of NAS 110 w/basket WhiteD90 Misc. Chit-Chat 6 January 29th, 2008 09:31 AM
Stock height aftermarket springs? lmaldonado Defender Technical Discussions 3 June 29th, 2005 08:23 AM
Proper waterpump torque? cgalpin Defender Technical Discussions 11 April 17th, 2005 09:45 PM
