Prop Shaft UJ lubrication - some questions :) - Defender Source
Old April 16th, 2016, 12:33 AM
agentmulder
Agent Mulder
2008 110 PUMA
Gidday,
Fun times under the machine this afternoon.
Front prop shaft:
Front UJ nipple found - all good, greased up and no play
Slider nipple found - greased up, no play
Rear UJ nipple ... not found .... wait ... roll the vehicle so prop is 180 ... um, yeah, not found.
Is this normal for the rear of the front shaft to not have a nipple? (why??) - I cant feel a hole anywhere either...
Rear prop shaft:
Rear UJ nipple - hrrrm, ok lube goes in but feels under pressure - when I push in the small nipple bearing it squirts out, indicating pressured air was in there (yeah?). I go to town on the grease gun and get some grease popping out, but only from two of the UJ arms. The other two, I assume, remain 'dry'
What to do about this dry situation? Does this pretty much force taking off the shaft and getting into it circlip pliers and all?
Advice - as always - appreciated, cheers!
Old April 16th, 2016, 12:47 AM
If they are not loose or seized they are okay. IME the non greasable quality joints last a lot longer than the greasable ones. They have much better seals.
Old April 16th, 2016, 01:12 AM
agentmulder
Agent Mulder
2008 110 PUMA
So the one without a nipple is a closed unit? Seems odd.
I would have thought lubing them maintained that 'not loose or seized' state...
The back pressure on the grease gun concerns me - air correlates with dry.
Land Rover Prop Shaft Tools SafariHP The Vendors Loft 19 July 12th, 2011 06:48 AM
New Defender Genuine 90 Rear Prop Shaft NOS FS $200.00 SafariHP The Vendors Loft 1 April 12th, 2009 12:34 AM
DII Front Prop Shaft Recently Rebuilt Paul Grant For Sale - Parts 0 December 11th, 2008 10:16 PM
Land Rover Prop Shaft Tool SafariHP For Sale - Parts 70 January 30th, 2008 08:21 AM
Series Rear prop shaft, new. KevinNY For Sale - Parts 1 July 15th, 2006 04:28 PM
