Prop shaft removal oops - Defender Source
Old February 18th, 2012, 02:45 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
So how important is the marking of the prop shaft? I didnt think to do that at all. But looking on the RAVE cd for the u joints I got the oh $hits when I saw that you are supposed to mark them.
Front I can remember where because I had hit the hut with a torch. and i can tell where i did that.
Rear not so much.
Those nuts were on there crazy hard. Parking brake made a good assist though. But not sure if that was the optimal solution. I cant imagine my ability to apply toruqe is anything near that weight of a vehicle.
Also there was a table spoon or 2 of gear oil that came out of the flange when it was seperated from the front output on the transfer box. Any thoughts there?
Thanks.
Pete
Old February 18th, 2012, 04:32 PM
Shouldn't matter on prop shaft placement. I assume you have not taken the splines apart.
Are you saying there was oil behind the u-joint flange? If so, make sure the t. case flange nut is tight. If it is tight, then remove and replace the felt seal that is behind the washer.
Old February 18th, 2012, 05:03 PM
Broncoduecer
peter
D90
Yea there was oil behind the flange. I will take a look and see if its tight. Thanks!
Old February 19th, 2012, 01:51 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I'm not clear on what you didn't mark. The propshaft in relation to the output and input flanges? Or the relation of the flange yokes to the shaft yokes?
If the former I wouldn't worry about it. I've never understood them saying to mark them.
If the latter, there's a good chance you'll need to get the shaft balanced.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 19th, 2012, 02:00 PM
Broncoduecer
peter
D90
It was in relation to the output and input flanges. I've been able to keep the yokes as they were.
I can't think why it would make a difference on the input and output flanges.
Thanks!
Old February 19th, 2012, 02:16 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I have never marked my prop shafts and I've never had a problem. Some aftermarket shafts, like the old GBR models, had a seperate adapter that was marked and aligned with a mark on the shaft. I believe this is because the two-piece assembly was balanced together and you need to maintain the orientation to maintain the balance.
I always use Snap-On Flank Drive wrenches to remove the nuts. The Flank Drive Plus open end is the ticket to get the nut loose without rounding it off. I have two SOEX18 wrenches for this purpose. A ratcheting box end wrench would be useful to quickly remove the nut once it's loosened; I need to pick up a SOEXR18 from the Snap-On guy when I see him.
Old March 4th, 2012, 10:17 PM
Broncoduecer
peter
D90
Whats the best way to remove and reinstall said nut? Rave cd says 120ft-lb so that has to be a chore to remove and to get torqued back up. Park brake trick ? I'm wondering what to use as leverage to get it off and on.
Pete
Old March 4th, 2012, 10:45 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
If you have pulled the slip joint apart on the drive shafts, the yokes on each end of the shaft do have a "timing" aspect to them in relationship to one-another. The service manual shows this sequence. I believe the front is about a 1/4 turn out of sequence end for end. The rear, I think is the same, end for end.
The balancing of the shaft is another issue.
Old March 5th, 2012, 05:44 AM
Antichrist's Avatar
Antichrist
Tom Rowe
For torquing I use a wrecking bar wedged between two adjacent bolts and the ground or chassis.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 5th, 2012, 06:35 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
To hold the output flange I prefer a piece of heavy steel (1/4" x 2" x 24") with 2 of the 4 holes for the drive shaft drilled in it. then you can just bolt it on and not have to worry about things flying and or damage to the bolts.
Matt Browne
Old March 5th, 2012, 09:13 AM
Broncoduecer
peter
D90
Thanks for the tips guys. I have some good options to try now. I knew there were some good ideas out there.
Old March 5th, 2012, 10:25 AM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
So is using the parking brake a bad idea for some reason? Seems like if it can keep thousands of pounds of truck from rolling down a hill it can handle 120 ft lbs no?
Old March 11th, 2012, 06:49 PM
Broncoduecer
peter
D90
So the nut was barely on. That would be why it was leaking I suppose. I put some nuts on the bolts and used the pry bar trick. Did the job just fine. Thanks Tom for the tip. I ended up getting a whole kit so I put in a new seal and got a new flange, lock nut, and felt washer.
I was also replacing the shocks this weekend. Rears were super easy to do, and super shot, so good thing I was replacing them. Just about had the first of the front ones done, but while tightening the nuts on the retained ring -SNAP- annnnnnnd F word. So I ordered up some new rings. They looked to be fine, I soaked them in PB for a few days and they came off super easy. It wasnt getting tight and it just snapped.
So looks like I will be dropping the axle anyways. So I think front shock number 2 will just get slipped out and not screw with the other ring.
Old March 11th, 2012, 08:31 PM
Parking brake is fine. The engine puts a solid 2000 lb-ft plus on those shafts.... 120 ft-lb is nothing.
Old July 22nd, 2012, 09:40 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I got my new front and rear prop shaft this weekend. One of the U-joint cups on the front shaft arrived damaged so I decided to replace all of them with a set of heavy duty U-joints. It didn't go so well. Despite banging on the front output flange yoke like rabid crack monkey I was unable to remove the last two cups from the yoke. Since I don't have a vice I figured I'd just take it in before I destroy it completely. Is it structurally bad for the yolk to have hammer marks on it? Should I replace it?
Balancing was also mentioned here. How is that done? Should I be concerned with this when replacing the prop shafts?
Old July 23rd, 2012, 05:55 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Instead of beating the crap out of it, why didn't you return it? I don't think I'd accept a new propshaft that was damaged.
In any case, a few hammer marks won't hurt it, depending one where they are. If you deformed the yoke so the cups won't go in, or come out, then yeah, that's not good.
A new propshaft should already be balanced.Provided you keep the yoke oriented the same way to the shaft (mark it with a center punch before removal) you should be fine.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 23rd, 2012, 09:24 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Return shipping to the UK will probably be more than what I paid for the damn thing. That said I am awaiting a response to hear what they'll offer.
I was just trying to follow the workshop manual instructions when I realized that a vice would be very helpful in this case.
Old July 23rd, 2012, 11:26 AM
You have essentially cold worked the yoke. Cold working increases tensile and yield strength. It decreases the total amount of deformation before tensile failure.
Old July 23rd, 2012, 11:55 AM
If memory serves, one would want to remove the shaft side cups first before the yoke side. In this way, you don't really need a vise. Use an old socket of the approximate diameter of the inside of the cup bore, and knock the cup out from the opposite side, then flip and repeat.
With the yoke off the shaft, you should be able to knock the cups out by the same method as above. You could use a large socket on a concrete floor and whack downward. A little sporty to try to hang on to all that mess and still get the hammer on the proper target, but do-able. No need to hit the shaft or yoke under any circumstance, vise or no vise.
Old July 23rd, 2012, 12:24 PM
Don't worry about the hammer marks. Though, you should not have to hit the u joint too hard to get the cups moving. If you damaged the bore that the cup goes into, you can get away with a little judicious filing as long as it is just at one end of the bore. BTDT.
My gut feeling is that lots of bad things will happen in your drivetrain before the potentially decreased performance of those yokes becomes a factor.
Using a hammer to get the u joints apart actually works quite well and reduces the odds of one of the cups going diagonal and really ruining the bore. Doesn't much help with getting them in though...
And its a yoke, not a yolk. Yolks are yellow and usually appear on breakfast plates. That is really the best way to tell the difference.
Tom Wood Custom Drive Shaft: My story. :) Roving Beetle Misc. Chit-Chat 5 April 21st, 2012 01:37 PM
New Defender Genuine 90 Rear Prop Shaft NOS FS $200.00 SafariHP The Vendors Loft 1 April 12th, 2009 12:34 AM
DII Front Prop Shaft Recently Rebuilt Paul Grant For Sale - Parts 0 December 11th, 2008 10:16 PM
Land Rover Prop Shaft Tool SafariHP For Sale - Parts 70 January 30th, 2008 08:21 AM
Lt77 Output shaft replacement Hans Defender Technical Discussions 5 December 9th, 2005 04:33 PM
