Progressive Coils Springs - Defender Source
Old September 1st, 2010, 12:07 AM
D90DRC
D Cantrell
1997 D90SW
Does it matter if the heavier wrapped section is up or down?
Still waiting for the Hope and Change to start
Old September 1st, 2010, 08:18 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
"they" say that the closest coils should be at the top, not sure why; i've heard that the wider space at the bottom allows mud/stones etc to fall out.
I can't see that it would make any difference to the actual physical compression of the spring, after all, the spring itself wouldn't know it the axle was coming "up" or the chassis/body coming "down" onto it.
Old September 1st, 2010, 09:46 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
On some springs, it can be hard as hell to install the lower retainer if its upside down.
Old September 1st, 2010, 09:51 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Last time we talk about that..... uh, have a seat and a little pop corn...
- Charles Eames
Old September 2nd, 2010, 12:06 AM
D90DRC
D Cantrell
1997 D90SW
JFD sorry to offend... Im sure all your questions over the years were never asked in this forum
Old September 2nd, 2010, 08:43 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
No offense at all. There is a long thread somewhere about that particular matter, maybe it's time to bring it back. When you read it, you'll need some popcorn and a soda too...
------ Follow up post added September 2nd, 2010 09:35 AM ------
Found it, it's called "progressive coil springs (SG)", started by Gustavo, april 2009. I don't know how to upload link as i'm writing this using forum runner.
- Charles Eames
Old September 4th, 2010, 12:08 AM
There are two reasons for coils at the top...
1) It reduced unsprung weight. In reality, on a Land Rover, it is not something in the realm of calculation.
2) To reduce the chance of stuck being caught in the springs or it holding mud. At normal ride height, the close coils should be very close to touching.
coil
Progressive Coil Springs (SG ) Rugbier Defender Technical Discussions 77 April 19th, 2009 07:57 PM
Safari Gard Progressive Coils SafariGard The Vendors Loft 2 March 8th, 2009 03:06 PM
D90 Springs... arbik Wanted 2 March 25th, 2006 10:09 AM
Stock height aftermarket springs? lmaldonado Defender Technical Discussions 3 June 29th, 2005 08:23 AM
new springs? scoloco Defender Technical Discussions 4 April 5th, 2004 06:08 PM
