programable intermitent wiper relay - Defender Source
Old December 19th, 2012, 09:19 PM
anyone fitted one ?
AMR2341DELAY - Wiper Relay Unit - Programmable
NOW 29.50 (excl VAT)
Quantity
Description
AMR2341DELAY Fed up with your intermittent wipers not being intermittent enough? Does it drive you mad when you give the screen a quick spray and it wipes for ages?
Fit this new relay in place of the standard AMR2341 to your vehicle to solve this problem . Once fitted you press the stalk down so that the wiper wipes and then back off again, now count/wait till you want another wipe, switch the stalk down and leave it on, this timing will now remain constant till you set another timing the same way or turn off the ignition at which point the relay reverts to a standard 6 second wipe interval. Another bonus is that the wipers will now only wipe once following a short burst of washer fluid or 3 times after a long burst.
This will work on all Defenders with the latching intermittent wiper stalk PRC7370 or AMR6106 HA onwards (stays down when pressed) but it will also work on 300Tdi and Td5, although on post 2002 Td5s the relay AMR2341 is located behind the speedo. It is also suitable for 2007 onwards Puma. Will not work with early stalk PRC3900 up to GA models.
Old December 19th, 2012, 09:50 PM
HeloBubba's Avatar
HeloBubba
Chris Murphy
'89 127 (D130), '16 LR4
Hi, Doug-
I've fitted them, but instead of spending a whole bunch of dough on one of those specific ones, I just bought a VW/Audi "99." relay, which I believe to be the same in a different package and price point.
It was a direct fit in my 94 (and I plan to use one in my 97 as well), and can be found on Ebay, etc for between $10 and about $22. I found several write-ups about this option on some of the UK-based forums, and worked like a charm.
Murph
Chris Murphy
'89 D130SW
'86 D110 3-door
'89 D110SW
'16 LR4
Former:
'97 D90SW - SOLD SEP '14
'94 D90ST - SOLD MAY '13
D90s sold while assigned overseas. You're welcome America!
'06 Range Rover Sport Supercharged
'8X FankenRover D100
Old December 19th, 2012, 10:22 PM
Originally Posted by HeloBubba View Post
Hi, Doug-
Murph
Outstanding Chris ! Have one on the way for $11
link if anyone else wants to plug in programable intermitent wipers
http://www.ebay.com/itm/VW-Audi-Volv...ce21fe&vxp=mtr
relay
Where is wiper relay on a 97 D90 LenB Defender Technical Discussions 6 December 18th, 2007 11:53 AM
Relay replacement help cgalpin Defender Technical Discussions 21 April 18th, 2005 07:42 AM
Locating the rear wiper pepstein Defender Technical Discussions 0 April 2nd, 2005 09:56 AM
Wiper Blades going haywire... arbik Defender Technical Discussions 4 February 22nd, 2005 11:07 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
