Problems when it rains... - Defender Source
Old October 27th, 2014, 02:45 PM
neilraymondjr
Jed Raymond
1994 NAS D90
I have a 94 NAS D90 that seems to hate the rain. Here are the symptoms:
1) It starts and runs find in the beginning.
2) After a few miles or so, if I come to a stop, and put it back in gear to move again, the rpms drop and the engine sputters then stalls.
3) the ensuing effort to get it going again is fruitless. It turns over, but never catches. If I didn't know any better, it feels like either engine is flooded, but I don't think that's what's actually happening. My suspicion is that something is keeping the combination of oxygen and fuel from getting where it needs to be in order to respond to the throttle pressure from a stop.
4) After the truck stalls, it needs about an hour or so of sitting quiettly, then it will start right up. This is the part that reminds me of flooding problems.
Rovers North in VT suggested the distributor cap. I've seen other thoughts that it may be the resistor servicing the EFI wiring harness. Any thoughts would be appreciated.
Just to be clear, this only is an issue in the rain, and for whatever reason seems particularly troublesome when strong winds are a factor.
Old October 27th, 2014, 03:25 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
I experienced the same issue years ago. It was a crank sensor that had cracked from the heat and allowed water to seep in.
Black Rhino Lives Matter
Old October 27th, 2014, 03:30 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
I've seen more than one rover V8 get condensation/moisture in the cap from driving in heavy rain, and exhibit these symptoms. Easy enough to 'pop' the cap off when its doing it and see if there is moisture in there. If so get a genuine replacement (and a rotor too)..
~Scott T.
'95 D-90 ST - AA Yellow
Old October 27th, 2014, 08:14 PM
You could have a bad connection somewhere and the rain is just making the problem worse. A basic tune up is a good idea if you don't know the service history, but really you're just guessing. Any check engine light?
Old October 27th, 2014, 08:52 PM
the rover shop
shayne young
As jimmy says.. Basic engine tune..cap, rotor, wires and plugs.. A bad cap or rotor or wires can cause exactly the symptoms you are describing with the extra moisture allowing the spark to jump to ground instead of going through the spark plug.. Basically, the spark is about as lazy as Pedro and will do anything to get out of doing its proper job and takes the easiest way out..moisture allows this to happen..
Old October 27th, 2014, 10:33 PM
chuckc4
chuck b
Registered User
I might double check the main ground wire where it attaches to the frame too. Detach, scrub away any corrosion, reattach.....
Old October 28th, 2014, 01:38 PM
neilraymondjr
Jed Raymond
1994 NAS D90
Nope, no Check Engine light
Old October 28th, 2014, 02:26 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I would recommend using a dielectric grease on the spark plug wires and the coil wire particularly where it mates with the coil
I don't know why the distributor cap/rotor needs to be genuine. But it does. I have had several aftermarket caps and none of them have worked well for me. Strange, strange, strange...
Old October 28th, 2014, 07:53 PM
Definitely true.
Old October 28th, 2014, 07:55 PM
the rover shop
shayne young
I have often found the aftermarket rotors allow the spark to go right through the centre to the dist drive post..
Old October 29th, 2014, 02:36 AM
gravitysucks's Avatar
gravitysucks
Andy
94 D90
Mine did the same a while back, turned out it was the ignition amplifier. It's bolted to the side of the distributor and was fairly easy to diagnose. I picked up a relocation kit and haven't had any problems since.
Old October 29th, 2014, 08:01 AM
the rover shop
shayne young
Just for future reference that ignition amplifier is just an ac delco part and can be bought at any parts store for like $12 for the cheap one and $36 for the premium one... It's the same as goes in many Chevys.
problems
Won't start...only when it rains gravitysucks Defender Technical Discussions 8 January 4th, 2006 12:07 PM
Tie Rod problems ... Help! Palmer Defender Technical Discussions 3 January 14th, 2004 08:41 AM
Problems with registering chrisvonc Support & Suggestions 0 November 7th, 2003 10:36 AM
Rust Problems boshea Defender Technical Discussions 6 October 15th, 2003 03:52 PM
Ignition problems boshea Defender Technical Discussions 7 October 7th, 2003 08:48 AM
