Problems shifting out of 1st when cold - Defender Source
Old July 14th, 2006, 10:39 PM
chalkcreek
Mark Williams
My '97 D-90 automatic tranny is having trouble shifting out of first gear afte a cold start (mornings etc.) Seems to run up to about 3,500 - 4,000 before it even thinks about shifting. After it has warmed up it shifts fine. Thinking that it may be a viscocity issue (cold no flow, warm good flow) I had a new transmission filter kit installed. This made it mildly better, but I am still concerned about the high rpm shifting in the morning.
Any help or suggestions is appreciated.
Mark
Old July 14th, 2006, 10:50 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
You might check first for a loose vacuum line. That happened on one of my automatic cars that would not shift out of first. A disconnected vaccum line was the culprit and the tranny shifted again.
Old July 14th, 2006, 10:56 PM
chalkcreek
Mark Williams
Thanks, am crawling under it (or into it) in the morning to look around.
problems
Shifting Problems Big D Defender Technical Discussions 8 July 3rd, 2007 11:11 PM
94 shifting problems jstrong98 Defender Technical Discussions 6 January 26th, 2006 03:06 PM
Cold Weather Starter Problems boshea Defender Technical Discussions 9 October 25th, 2005 04:35 PM
1st really cold weather questions mspell Defender Technical Discussions 6 December 20th, 2004 08:40 PM
? for you cold weather people javelinadave Defender Technical Discussions 8 November 24th, 2004 12:34 PM
