problems leveling D90 with OME Suspension - Page 2 - Defender Source
Old January 14th, 2012, 06:38 PM
Oliver Whiting
Oliver Whiting
84 110, 94 NAS90,Bunch of EX-mods
springs
Old Man Emu calls for 751 springs in the front of a Defender 90 and 764 springs in the rear. Rovers North Changes that up a bit for the heavy duty kit and uses the 762 rear springs that are progressive rate. Yes they are a little shorter free length but they are a stiffer rate spring using a larger wire diameter so it results in a lift.
Most OME springs are pretty close to the free length of spring Land Rover used.
If you have a TDI under the bonnet that engine is approximately 70lbs heavier than the 3.9 v8. I have always had good luck using the Old Man Emu 767 front springs if you are also adding a bull bar. The ride is not harsh as that is usually down to the shocks. The 767 or 2767 as they all have the number 2 in the new part numbers are for a Defender 110 front.
OME springs are handed
Spacers are a quick fix. If the springs are sagging due to load the spacers will not help in the long run.
Old January 15th, 2012, 08:54 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Originally Posted by tomaco1 View Post
Is it just the weight of the tdi?
The hd in back would obviously be higher than medium, right.
I kinda liked the simple spacer under the front spring perch.
Yes the Tdi is heaver than the V-8 by about 133 pounds, if my math is correct. The 3" RTE springs work very well to give you a 2" lift if you have the 2" springs on the rear. The spring will also give you a little bit more articulation as compared to the spacer.
Land Rover 110
90, d90, problems
speedo for 97 D90 ome mjekogian Wanted 2 February 14th, 2006 12:53 PM
OME suspension id kolvedic Defender Technical Discussions 1 August 15th, 2005 01:46 PM
OME suspension scubadanster Defender Technical Discussions 19 February 25th, 2005 09:37 PM
D90 Suspension Upgrades? Inkopah_D90 Defender Technical Discussions 6 June 16th, 2004 07:12 PM
OME suspension, and tires huntahdefender Defender Technical Discussions 4 October 10th, 2003 04:14 PM
