Problem's - Defender Source
Old August 8th, 2014, 08:32 AM
87'Cav..,97'Cab's Avatar
87'Cav..,97'Cab
Ryan
1997, Defender 130, 300 Tdi
Problem's
Scraping sound coming from motor bay when foot is on clutch and big rattle when I turn it off...Only started two days ago! Any ideas anyone?
Old August 8th, 2014, 08:47 AM
Clutch release bearing worn. Sign of impending doom. Time to break open the wallet and get it fixed
Old August 8th, 2014, 09:17 AM
I had that scenario once and it was one of the bolts that secures the bell housing to the transmission had come loose and was rolling around screwing everything up.
Old August 8th, 2014, 10:34 AM
DannyboyUpstate's Avatar
DannyboyUpstate
Danny Harrington
1983 110 3-door
Wow... that's unexpected.
Old August 8th, 2014, 11:48 AM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
Mine did the same when the throw out bearing was failing. The rattle might be the springs on the clutch disc. The clutch disc pads still had life, but it was time.
Get this done sooner than later if you know what I mean.
"Uhh...I think they all leak like that."
Old August 8th, 2014, 03:55 PM
87'Cav..,97'Cab
Ryan
Cheers all for the feed back.., have parked up the tank and will be onto it first thing!!!
Old August 8th, 2014, 03:57 PM
87 D110 (Ruby)
Rockingham ay! I am from Kalamunda
Old August 8th, 2014, 05:31 PM
350rangerover
3
X2 on a bad throw out bearing
Old August 11th, 2014, 03:36 AM
87'Cav..,97'Cab
Ryan
All way off.... But cheers anyway! ( broken Air Cleaner mount ). Who's got a spare they don't mind parting with?
Alternator/Battery problem - Repost Eric_S Defender Technical Discussions 1 January 19th, 2004 09:57 AM
Need help with D90 engine problem Chris Cox Defender Technical Discussions 3 January 10th, 2004 08:41 PM
D90 Ground Problem? cdnpaul Defender Technical Discussions 0 December 4th, 2003 03:36 PM
Odometer problem 97 jorge Defender Technical Discussions 3 November 19th, 2003 01:13 AM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
