Problematic Brake Drum - Defender Source
Old November 25th, 2006, 09:51 PM
punter
1966 Series IIA
Anyone have a trick for removing a stuck brake drum?
I'm about to just disassemble the hub assembly; remove the hub and drum together; then try to bang 'em apart.
...hoping that someone's got a better idea.
Old November 25th, 2006, 10:52 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
There are brake drums that aren't stuck? I've almost never had one come off easily, and the ones I did get off easily.... they were missing parts.
Usually you want to back off the star adjuster first, which is accessed through a hole in the backing plate. This releases the tension from the pads themselves, you would want to check the manual on how to do this. (please, do this with either the tires on the ground, or on GOOD jack stands. Up on a jack is never safe to be under a car/truck). Then bonk the flat face of the brake drum with a BIG hammer a few times, a good deadblow or 1lb sledge work great. Most times this will loosen it up enough. Sometimes you may also want to heat the drum with a propane torch, as this will help to break any rust that might be holding it on.
-Hans
My oil line fix
My 100k stopped odometer fix
Old November 26th, 2006, 12:12 AM
Back off adjuster. Wrench pointing to front of vehicle and turn UP.
Put bolt in drum removal hole.
Tighten bolt while knocking drum out around in different location to keep it square.
Old November 26th, 2006, 07:46 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
What truck
Old November 27th, 2006, 09:02 PM
punter
1966 Series IIA
1984 Defender 110
Old November 27th, 2006, 11:23 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
there are 2 adjusters[1 for each pad] back those off & see if that helps
report back
Old November 29th, 2006, 08:04 PM
punter
1966 Series IIA
Yep, I had already backed them off... I've been recommended to try the Big F***ing Hammer Method by some folks on another site. So, I'll give that a go as soon as I'm able to get back to it.
Punter
Old November 30th, 2006, 08:52 AM
I think there is a threaded hole on the drum (my memory fails me if this is series only or not). Whilst hitting it with the bfh put a high grade bolt in there and turn as the bolt pushes off. My experience is that, if it is not simply rust, the shoe wears a ridge into the drum and that locks it in place so wacking the outside of the drum sometimes frees it.
Old December 2nd, 2006, 12:43 AM
punter
1966 Series IIA
glencoyne wrote: Hit the face of the drum - not the edge, and especially not the rim, with the biggest hammer you can find. Screw the wheel nuts a few turns onto the studs first, so you do not hit the ends of the studs and damage them. Even the most stubborn drum will 'bounce' free in the end. If it still does not shift, you are using too small a hammer.
Richard
This was some advice I got on another site... it worked perfect. Drums popped off easily and no damage to any parts.
I did see the threaded hole you were referring to... there was a lot of rot in it though. So, I wasn't confident that the treads were in tact enough to withstand the force required to pop the drum free. Now I know what that hole is for though (for the future)... oddly, the shop manual for my truck makes no mention of it.
Thanks for all the advice,
Punter
brake
parking brake drum ZACHASS Wanted 2 March 30th, 2009 01:55 PM
FS Salisbury Drum Brake Parts Stmpede For Sale - Parts 3 December 18th, 2008 08:02 PM
Wanted E brake drum for and lt 230 TDI Guy Wanted 3 November 10th, 2007 01:45 PM
110 drum brake shoes FS ECR For Sale - Parts 5 July 23rd, 2006 09:03 AM
D-90 rear drum brake axle assembly TDI Guy For Sale - Parts 0 November 6th, 2003 04:59 PM
