Problem finding pipes fir 200tdi injector pump - Defender Source
Old October 18th, 2016, 03:51 PM
Bigloui99
Louis
Defender 90 1987
Hi
Does anybody know what the bottom pipe on the back side of the injector pump is not the one with the banjo connection the one that goes from plastic coated pipe with a normal connector then a metal pipe into the injector pump it's leaking fuel quite bad so I tried to remove pipe and it just disintegrated when I put spanner to it
Have seen it referred to ass spill off pipe? But can't find it anywhere online to buy any help greatly appreciated
Old October 18th, 2016, 07:34 PM
MattH
Matt
1998 Defender 110 Stn Wgn.
Are you talking about the low pressure fuel return? If so you can use some air brake hose. It's available everywhere in different sizes and is super cheap.
Old October 20th, 2016, 11:24 AM
east high's Avatar
east high
Gerad Davis
1967/s2a 88 200Tdi
I'm not sure which end disintegrated, but more often than not the fittings are part of the lines and not a separate item.
200tdi, tdi
Discovery 200tdi injector pump return line richord Defender Technical Discussions 4 October 3rd, 2016 07:16 PM
200Tdi Discovery injector pump to fuel filter pipe part number richord Defender Technical Discussions 5 July 26th, 2016 07:13 AM
300tdi fuel injector pipes Broncoduecer Defender Technical Discussions 0 March 12th, 2016 05:56 PM
200TDI injector/fuel pump johnnyb77 Wanted 2 June 16th, 2014 05:47 PM
Subsitute fir Hylomar? Grover Defender Technical Discussions 2 November 4th, 2008 10:30 AM
