Priming Oil Pump - Defender Source
Old April 28th, 2004, 01:09 PM
chrism
Chris Musni
1996 Range Rover 4.0 SE
Question Priming Oil Pump
We're replacing the oil pump/front cover on my 4.0 SE. The FSM pretty much covered all the steps exept for priming the PUMP. I've heard about packing the pump with Vaseline, Just trying to find out if there are other alternative priming procedure that anyone knows of out there. Thanks for your help.
Old April 28th, 2004, 01:52 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
This is from a friend -- haven't actually done this myself: "Remove the oil line from the bottom of the engine (this is the oil pump output). Spin the engine with the starter motor a few seconds at a time until oil comes out of the line. May take a few tries."
DW
Old April 28th, 2004, 05:28 PM
chrism
Chris Musni
Thanks, I read something that described the same method. We will definitely try it. I appreciate the input.
Old April 29th, 2004, 03:53 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Either pack the pump with vaseline and turn the engine over as normal or f you're worried about the bearings running dry (and you should be)
whip the distributor off and get an electric drill down the hole to spin the pump gears without turning the egine over. you'll need to make up some sort of shaft to fit in the drill that mates with the slot in the pump shaft.
Mike Hammond
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
Oil Light Flickering/Oil Pump Glenn_Guinto Defender Technical Discussions 13 October 27th, 2004 08:27 AM
