Pressure Washer Recommendations - Defender Source
Old October 5th, 2009, 05:04 PM
firemangreen
Justin
97 D1, 95 SW, 65 IIA
After a great MAR 2009, I'd rather not continue to keep the local spray wash place in business. I still have a lot more mud to get off the underside of the truck. Anyone have any recommendations on gas powered pressure washers?
Brand? Engine HP? GPM? PSI? Extra Features?
I've used a couple of different brands, Sears, Excell, etc. but don't have detailed experience with them. TIA.
97 D1
95 SW #129
65 IIA
Old October 5th, 2009, 06:55 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Pressure wash force water where it is no supposed to go .
My 2c, it's a no no.
- Charles Eames
Old October 6th, 2009, 08:45 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I have some Lowes-Troy Bilt-Honda powered model that has worked well. Nothing crazy. I would recommend getting the staun massojet attachment sold by a few vendors. Also, even with a lifted d-90, you'll find it hard to maneuver the wand when underneath the truck. I'm currently in search of a shorter wand to use in tight spaces.
Old October 6th, 2009, 09:06 AM
Justin I have a little gas powered (honda engine) unit which works well - including decks, siding etc. I'd need to go out and look to tell you the name and model if you want, but I think I got it at the Home Depot or Sears the like.
But you should try putting a sprinkler under it and move it around every 10 minutes. It slowly eats into the mud and loosens it up. I can't tell you how this works on Airy Hill Farm mud though as I haven't washed my truck yet.
Old October 6th, 2009, 09:27 AM
bitz's Avatar
bitz
Jon
NAS D90, 85 D110 CSW, 66 Dormobile
http://www.homedepot.com/Outdoors-Ou...atalogId=10053
My buddy has this one and it works awesome. But be careful it will strip paint if you use the high power nozzle.
So would you just recommend leaving the mud packed in?
Old October 6th, 2009, 11:06 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Try to decide how heavily, and for what you will want to use it. For auto clean-up, some of the better Electrics are easier to deal with, require less maintenance, and provide plenty of pressure (you don't want to overdue it with washing vehicles). If you also want to use it for washing your deck, driveway, etc, you will want to consider one in the 2600-2800 psi range minimum, and that puts you into gas powered units for the most part.
I have an older Tory Bilt 2600 PSI (bought at Lowes) that has worked well for the household duties, but honestly I don't use it for the cars/truck, but the low pressure tips it comes with would be fine for mud cleaning duties. It has a Honda 'GC' engine, with is Honda's homeowner grade engine, the professional units use 'GX' series engines, which are reportedly more robust, durable and reliable, though I've had no issues with mine...
~Scott T.
'95 D-90 ST - AA Yellow
Old October 6th, 2009, 11:10 AM
firemangreen
Justin
Good info everyone! I've asked around at work and it seems that the honda powered pumps seem to work the best and 2300-2500psi is strong enough to get the dirt off but not strip paint.
Julien-Good point, but I don't want to encourage rust by leaving the mud on there and for the Airy Hill Farm mud, a pressure washer is more effective.
Charles- I tried that but to get in to the cracks, I need something a little more powerful. I swear the mud I plowed with my front bumper on 1D is a second cousin to cement!
David- I'll be looking for the massojet and you're right, it seems that no one makes a short wand. Let me know if you find one somewhere.
Jon-Thanks, I'll have to check out the local HD.
If money were no object, I'd get one of those steam pressure washers, aka a Steam Jenny. We unintentionally did a little off roading with a truck at work in a recycling/wood chip yard and buried it. The local quarry let us use their Steam Jenny and the underside wound up clean enough to eat off of!
97 D1
95 SW #129
65 IIA
Old October 6th, 2009, 11:57 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
This may be a lark but i recall seeing a bendable wand attachment for power washers in one of the rover magazines within the past 3years i would say.
Old October 6th, 2009, 12:01 PM
Michael
Michael
Discovery 1998
What do they use at Robisons to prep for waxoyl?
Old October 7th, 2009, 01:11 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Garden hose with regular nozzle and a little bit of patience.
I have to say i like the sprinkler idea, not so agressive as
the power washer .
- Charles Eames
Old October 7th, 2009, 02:09 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Consider the pneumatic kind, you use a normal 30psi source though so for on-trail use you need a lift pump and oba but they work well enough and would be less likely to strip paint etc and are very compact. I think this is the route I will be taking with the 110 since I plan proper oba and pressurized water supply(and RO filter) anyway.
Old October 7th, 2009, 02:19 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I used this technique over a 3 hour period on Sunday and it got 90% of the mud off of the truck.
Old October 7th, 2009, 02:20 PM
I have a wand that attaches to a normal hose to boost pressure. I put on a diving mask and a snokle and get under when I have to clean one of the trucks. It works fine with a stiff brush to get it clean.
Old October 7th, 2009, 06:10 PM
Grover's Avatar
Grover
Talking
...use this and a garden hose...
Station Wagon Rear Washer Squirter mhansen Defender Technical Discussions 2 March 14th, 2009 10:33 AM
BF Goodrich Tyre Pressure Recommendations Manimal Defender Technical Discussions 5 November 5th, 2008 11:43 AM
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
97 low pressure A/C hose source dnewman9 Defender Technical Discussions 1 June 15th, 2004 01:39 AM
