Pressure cap diagnosis - Defender Source
Old May 10th, 2015, 07:07 PM
I've been having overheat issues that are symptomatic of air in the system/air locks with the temps normal for a while than a sudden spike. Had it diagnosed locally at a shop with diesel and rover experience, and they said it just needed to be burped more. Have gone through air bleed cycles several times and had another major over heat. Everytime i think this system has been filled finally , I'll end up a day or two later with another overheat (and immediate pullover-rest). After each overheat, then next day after a full cooldown, the radiator tank it low and the expansion tank is high.
shop confirmed t-stat was working fine and said they don't think there's an issue with the headgasket as no gas has been observed in the coolant with engine running.
After longer runs where the engine gets good an warm, when I stop the engine and get out, I can hear a slight hissing from the expansion tank and sometimes the pressure cap will purge some fluid.
I just replaced the pressure cap with a new one, and will test drive it tomorrow. But for a properly operating 300 tdi, how do you know when the system has been bled properly? For a completely bled system, would the t-stat fill plug always be completely full when removed cold, or would there be some air in it?
My understanding is that the fill line in the expansion tank is the same level as the radiator fill plug. What would cause the radiator level to drop and the expansion tank level to rise?
Also, if my old pressure cap didn't seal well on the threads under pressure, what would be the symptoms observed from that?
I'm starting to lose confidence in this 2.8 engine. It's been a run of trouble.
Mark Kellgren
KM4BOR
Old May 10th, 2015, 07:20 PM
Sounds more like a head gasket, cracked block, or cracked cylinder head. The hissing from the cap is probably due to the system being over pressurised. I would recommend getting a block test kit to see if you are getting any combustion gases in the cooling system. They don't always detect combustion gases, but if it does, then you know there is a big problem. How long does it take to overheat?
Old May 10th, 2015, 07:30 PM
i couldn't detect combustion gases with one of those kits ... you might have better luck.
can you have the truck filled with coolant under vacuum ... that would eliminate any burping issues.
What would cause the radiator level to drop and the expansion tank level to rise? ... excess pressure would
Old May 10th, 2015, 07:49 PM
overheat is very random. it can go a few days sometimes. It's going back to the shop tuesday for further diagnosis.
I did the headgasket in the fall. had the head shaved (had no warp) and pressure tested. I've did a pressure test today and the system was able to hold at 13psi for an hour.
Mark Kellgren
KM4BOR
clutch problem diagnosis help... bharris Defender Technical Discussions 18 November 14th, 2011 04:42 PM
need help with diagnosis of 3.9 fuel problem Art Vigil Misc. Chit-Chat 15 July 7th, 2010 01:07 AM
Trail break diagnosis phoenix37 Defender Technical Discussions 15 July 27th, 2009 02:41 PM
OBD2 - P0420 Diagnosis pcscharfe Defender Technical Discussions 1 January 12th, 2008 02:28 PM
Clutch issue? Help with diagnosis..... Hans Defender Technical Discussions 13 December 18th, 2005 05:19 PM
