Pressing brake pedal turns on parking and brake lights - Defender Source
Old August 27th, 2015, 09:58 PM
burlsube
Nick
1985 110 CSW
I noticed tonight that when I depress the brake pedal my parking lights and my brake lights turn on. Intermittently it seems like the brake lights will start working as they should - only when the pedal is depressed. I verified that the ground on the battery is good, clean and tight.
The issue presented itself when I installed leds around the truck. I thought they might be the culprit so I changed back to incandescent bulbs and the issue above still persists.
What am I missing? Is it the brake pedal switch?
Old August 27th, 2015, 09:59 PM
I misread your problem. Johns post below is what I think is going on.
Old August 27th, 2015, 10:01 PM
Most likely a bad ground at one of the lights. It feeds power back through the ground via the parking lights as they share a ground connection. Check the grounds at the rear lights first and make sure they are well connected to the body.
Old August 27th, 2015, 10:50 PM
burlsube
Nick
1985 110 CSW
Thanks. I'll give it a shot.
Would you recommend just making a new ground? I quickly tried to get the old ring terminal and ground screw out, but it is pretty .
Old August 27th, 2015, 10:58 PM
Nothing wrong with a new ground. When I installed new VDO gauges I made a new ground with thicker wire and new fittings just to be sure.
Old August 27th, 2015, 11:57 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
When I hit my turn signal (in either direction) my trailer light on the dash illuminates briefly. I wonder if this is the same issue, or perhaps just normal, since I've only driven the one D.
Old August 28th, 2015, 12:01 AM
That is 100% normal.
Old August 28th, 2015, 01:10 AM
D90Overkill
David Frank
1995 ST #2615
Thanks. That's good to know. I was just going to live with it anyways, but it's good to know that something else isn't falling apart! ;-)
Old August 28th, 2015, 10:56 AM
D90Overkill
David Frank
1995 ST #2615
Yup. That's what it does. Always thought it was strange to light up just the once so I thought something was a miss. When towing, it would blink as you described, so figured it was fine and maybe just a bit glitchy.
Old August 28th, 2015, 11:21 AM
burlsube
Nick
1985 110 CSW
Grounds tested good. Also, I noticed when I turn on the parking lights via the switch my brake lights come on full blast.
brake, ht, lights
Installed Momo wheel and hub, now have clicking noise whenever wheel turns bradfordish Defender Technical Discussions 8 September 3rd, 2013 07:46 PM
Parking Brake and Rear brake light gas-man Defender Technical Discussions 9 February 20th, 2012 11:40 AM
Left brake lights work....the right and door brake lights won't? beko35 Defender Technical Discussions 4 June 27th, 2009 02:12 PM
Engine turns over but won't start bd90 Defender Technical Discussions 9 August 8th, 2008 12:22 PM
pressing in plybushes? Chris Cox Defender Technical Discussions 2 October 13th, 2003 11:05 AM
