Preserving the bulkhead - Defender Source
Old February 26th, 2014, 09:20 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
What are some of the methods being used to preserve an original bulkhead? Given the multiple points of access, both of these products should be able to reach all the internal nooks and crannies:
Eastwood's internal frame coating:
http://www.eastwood.com/internal-fra...nozzle-qt.html
Waxoyl Rust Inhibitor:
http://www.roversnorth.com/ProductDe...AEROSOL&key=it
I've used both (fogged the door frames w/ Waxoyl and the chassis w/ Eastwood). Just wondering if there are better options or any long term feedback on the two.
Old February 26th, 2014, 11:55 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Long term I would galvanize them.
Old February 26th, 2014, 12:08 PM
Russell, I've used both - the Eastwood internal chassis coating I used on the 110 and plan to use on the 90 at some point. But on both the 90/110 I use the Waxoyl any in the bulkhead cavities anytime I have an opening (swapping out door hinge bolts, removing heater box, removing dash).
It seems that the Eastwood stuff is more of a "shell", whereas the Waxoyl is more of a "coating"...and for no real reason I've just felt that the Waxoyl seems better suited for getting into the nooks & crannies of the bulkhead internally.
It's also worth noting that the spray nozzle on the Eastwood stuff I'm not sure would fit nicely into the bulkhead openings (the holes are small), but it's great for the chassis holes that are in place.
Also, the Eastwood stuff - I'll forewarn you - is some serious stuff. Not sure I'd want that coming out of the bulkhead in places you weren't expecting. For example, I had painted the chassis on the 110 with 2 coats of Eastwood Rust Encapsulator and 2-3 top coats of Chassis Black Extreme. The Internal Frame Coating ate through these layers of paint like they were the icing on a birthday cake. Not sure what it would do to the plastic dash/etc should it make it to the interior.
Just my $0.02 and experience I've had with both.
Old February 26th, 2014, 12:45 PM
down_shift's Avatar
down_shift
Russell
Guess my question is really if Waxoyl converts and stop any existing rust as the Eastwood product claims to do. The more I think about it, I did spray Waxoyl in the bulkhead cavities when changing the door hardware to SS. So just accessing from those points.
The chassis coating is some slick and hot stuff. Glad you told me to tape all the access holes prior to fogging and go hole to hole covering behind you. Thankfully that green stuff was easy to wipe off when it ran out and before it hardened.
Old February 26th, 2014, 09:31 PM
the only rust I have on my bulkhead is from the leaky clutch mc's eating the paint off. I really like waxoyl its easy to apply and cheap. I wouldnt use it to "encapsulate" rust, I prefer ospho-> rustoleum-> paint-> waxoyl. I love coniston green spray paint
vin
Bulkhead Rust TurkD90 Defender Technical Discussions 4 May 14th, 2005 05:06 AM
For Sale Bulkhead removal bar TDI Guy For Sale - Parts 11 February 2nd, 2005 08:57 AM
Bulkhead Questions JimC Defender Technical Discussions 19 October 27th, 2004 01:00 PM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
Help with installing bulkhead on chassis Chris Cox Defender Technical Discussions 2 June 5th, 2004 09:33 AM
