Prepping the Bulkhead - Page 2 - Defender Source
Old January 11th, 2016, 01:46 AM
RBBailey
RBBailey
1965 IIa
Hu, never knew. Good idea.
I'll check tomorrow, but I think it is already opened up.
Project:
1965 IIa SWB
Old January 14th, 2016, 11:32 PM
RBBailey
RBBailey
1965 IIa
What is the proper way to get these things out, and where can I buy more?
Project:
1965 IIa SWB
Old January 14th, 2016, 11:40 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
If they are plastic speed nuts, remove screw from other side, pinch and push. Replace here:
Linky no worky. I'll find it in a munute. Sorry about the accidental double pic.
Old January 14th, 2016, 11:48 PM
RBBailey
RBBailey
1965 IIa
Thanks.
Not sure the pinch and remove is working right. They either come out with much pain, or they just break.
RN has them for either .45 cents... or $2.95....... Is there anything wrong with buying the ProLine here?
http://www.roversnorth.com/ProductDe...=PLC946&type=0
Did you mean to put a link there? All I see is two of the same pic.
Project:
1965 IIa SWB
Old January 14th, 2016, 11:53 PM
D90Overkill
David Frank
1995 ST #2615
Here it is:
http://www.roversnorth.com/ProductDe...e=0&eq=&key=it
------ Follow up post added January 14th, 2016 08:54 PM ------
Yup. You had it. RN site.
Old January 14th, 2016, 11:55 PM
RBBailey
RBBailey
1965 IIa
Yeah... I can't pay that. Going for the Chinese knockoff on this one...
Project:
1965 IIa SWB
Old January 14th, 2016, 11:59 PM
D90Overkill
David Frank
1995 ST #2615
They are probably identical. But if unsure about cheap Chinese plastics, I'd buy a set of each. Inspect and compare the quality of the plastic, and then send back the expensive ones if there is no difference. You just don't want the things to blow apart when you screw into them.
Old January 15th, 2016, 12:03 AM
RBBailey
RBBailey
1965 IIa
I'm reading it as that price for ONE since there is no indication of it being a set. If it was a set of 4-6, sure I'd buy.
Either way, I basically just needed to know I could get replacements from someplace before abusing all these that I'm pulling off.
Project:
1965 IIa SWB
Old January 15th, 2016, 12:07 AM
D90Overkill
David Frank
1995 ST #2615
Unfortunately, I'm certain that price is each, but pinching and pushing back through should save a few.
Then again, you don't want to be using your old ones, necessarily, as replacing these things again if they break won't be as easily accessed as they are now.
Old January 15th, 2016, 12:13 AM
http://www.paddockspares.com/cza4705l-nut-lokut.html
They are used all over the place. Buy them in bulk.
Old January 15th, 2016, 12:26 AM
RBBailey
RBBailey
1965 IIa
Ordering from Paddock work smoothly?
Project:
1965 IIa SWB
Old January 15th, 2016, 12:30 AM
TheOneTen's Avatar
TheOneTen
Eric Wages
1988 D110 300tdi/R380
I bet if you walked down to your kickass hardware store, they would have something very similar. I was able to source, right out of the hardware bins, the much smaller plastic nuts used in the bulkhead - either Ford or GM bits.
That is, unless you really want to know that you have purely overpriced British nylon nuts on your dash. The nuts won't know the difference
Old February 16th, 2016, 11:13 PM
RBBailey
RBBailey
1965 IIa
OK. I have the bulkhead stripped. What rust there was is fixed and patched.
So now I have it in my garage, and I'm rigging a lift it so I can hang it for the prep and paint.
I have a two-part epoxy primer and gun and all, getting ready to make final decision on color (hey, if I'm going to paint, why match the blue I don't like? More on this later.)
And I have two-part Hippo-Liner ready to go for the kick panels and such. (Also for the floor and seat box.)
QUESTIONS:
  1. The cleaner/stripper put on a "phosphate" coating after it was washed and dried. I asked them about what to do to prep for paint now, and they simply said to apply the primer right over this.... OK... well, I'm just a bit skeptical. I have an email in to ask for more specifics, and I've tried to find the answer on other forums, etc. It seems that you "can" paint over it, but a lot of people say to scotch bright it, then clean with acetone before painting. Prime right over, or acetone first? Both options seem logical in a way, but unsure for this particular project.
  2. Should I be liberal with the seam sealant, or careful to keep a tight bead and work it in without any over-spill?
Project:
1965 IIa SWB
Old February 16th, 2016, 11:57 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Not galvanizing it?
Old February 17th, 2016, 12:17 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I used DP90 two part epoxy. Now I have rust through on the A pillar I am getting ready to repair. GALVANIZE IT!
God I wish I did. When I did my frame and bulkhead, Colorado sanded roads. Now they use mag chloride and i battle rust. Should have galvanized everything... Lesson learned.
Old February 17th, 2016, 01:22 AM
RBBailey
RBBailey
1965 IIa
As I've said before, I can't argue with galvanizing, but at the same time we don't use salt. I am getting paint on the inside as well. And frankly, if I could find someone who would do the job, I probably would give it over to them to galvanize it, but two outfits in the area have told me they won't do it.
Project:
1965 IIa SWB
Old February 17th, 2016, 12:09 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Even without salt being used on the roads, it will still rust. You have done a TON of work on it so far, and if you go that little bit further, you will know it will NEVER rust again, ever. There has to be someone around there that would be willing to galvanize it.
If you contact American Galvanizers Association American Galvanizers Association I am sure they will put you in contact with a local company that would be able to look after it for you.
Once you get stuff like this done, you will realize you won't ever have to go back and do it again.
Old February 17th, 2016, 12:16 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Originally Posted by CDN38 View Post
Even without salt being used on the roads, it will still rust. You have done a TON of work on it so far, and if you go that little bit further, you will know it will NEVER rust again, ever. There has to be someone around there that would be willing to galvanize it. If you contact American Galvanizers Association American Galvanizers Association I am sure they will put you in contact with a local company that would be able to look after it for you. Once you get stuff like this done, you will realize you won't ever have to go back and do it again.
Best advice; they is likely a galv shop near you no matter where you are; certainly worth the drive for that kind of longevity. If you think it was a pain to do once try doing it twice
Old February 18th, 2016, 07:11 PM
RBBailey
RBBailey
1965 IIa
I've now had four different companies in the Portland area tell me that they won't do the job. I didn't tell the last two what the job was, only the approximate size and weight.
Project:
1965 IIa SWB
Old February 18th, 2016, 07:53 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
meh... I'm not galvanizing my bulkhead either, Ben.
Just throw caution to the wind and build it.
Rent my
Swapping a bulkhead to TDCI bulkhead WBSurfer Misc. Chit-Chat 20 September 23rd, 2015 10:19 AM
Prepping for a Valley pan gasket replacement, coupla questions flananuts Defender Technical Discussions 13 July 29th, 2013 10:06 AM
Prepping for series 2 REASSEMBLY! JBinAlabama Series Technical Discussions 5 October 31st, 2011 09:16 PM
Prepping for paint- advice please isleofbones Defender Technical Discussions 5 May 4th, 2009 12:26 AM
Bulkhead-preparation for painting? Chris Cox Defender Technical Discussions 2 October 24th, 2003 08:51 AM
