Prepping for paint- advice please - Defender Source
Old May 3rd, 2009, 02:24 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
Cool Prepping for paint- advice please
I'm just removing checker plating, wheel arches, badging, bumper, grill, etc. to get my rover ready for paint. I have maybe two spots that will need filler and have been advised to use filler specially engineered for aluminum/galvanized(like Wurth). I plan on simply sanding and using appropriate prep solvent where paint is solid. But, I don't know what to prime with on spots where I am doing work and sanding away the paint. Should I use a zinc chromate primer on these aluminum spots? What should I use to prime the galvanized cappings as I am going for the more modern d-90 look? Finally, does anyone have a recommendation for a durable paint finish coat... polyurethane, imron, etc. I'm not a big of clear coat finishes. One last thing... Where can I find the color match, code or a match for my current paint. Its an '84 d-90 with factory greenish aqua kind of color. Seriously, just one last question... do I have to worry about any of the common paints reacting with aluminum(ie do they have metal in the formulation: i don't mean metallic fleck paint)?
Thanks for the Advice,
Old May 3rd, 2009, 03:57 PM
Getting paint to stick to galvanizing it tough. For bare aluminium, use an etching primer.
Old May 3rd, 2009, 05:58 PM
isleofbones
Mike Deery
1984 D-90
Thanks for the advice.
Old May 3rd, 2009, 06:21 PM
RyanB16's Avatar
RyanB16
Ryan Hoffmeyer
94 D90 Red HalfCab #741
DP90 work fantastic for aluminum, and priming over filler etc. That is what they are using on mine currently. be sure to get the areas really rough where the filler will be used on the aluminum. it will have a much better chance of staying on where it was suppose to.
Old May 3rd, 2009, 06:30 PM
isleofbones
Mike Deery
1984 D-90
Ryan-
Sorry for my ignorance, but, what is dp90? Is it body filler or is it primer?
Old May 4th, 2009, 12:26 AM
RyanB16's Avatar
RyanB16
Ryan Hoffmeyer
Originally Posted by isleofbones
Ryan-
its an epoxy primer that is a superior resistance to moisture, corrosion and rust. it pretty much seals the panels completely. It is better to use an epoxy primer on areas that require filler. the bondo will stick a lot better on the DP90 then to bare metal and prevent it from rusting. once you seal the then entire car, you can let is sit for months before you paint it and not have to worry about rust. as for a non-epoxy primer that will actually absorb moisture and attack the panels underneath with rust.
I just went through all of this with mine. It just got painted last week and hopefully I will be picking it up tomorrow.
any auto paint supplier will know about DP90.
Ryan
paint
Requesting a little suspension advice nmc Defender Technical Discussions 9 March 19th, 2006 01:09 PM
Vibration location! Advice please.. EdF Defender Technical Discussions 11 January 1st, 2006 05:29 PM
Advice on buying my first D90 mtbrooks Defender Technical Discussions 7 July 19th, 2005 07:48 PM
auto transport advice mdmccallum Defender Technical Discussions 6 May 11th, 2004 05:58 PM
any advice or comments ccrover Misc. Chit-Chat 6 December 7th, 2003 11:43 PM
