Preparing Bulkhead for Galvanizing - Defender Source
Old November 16th, 2012, 07:04 PM
61rover's Avatar
61rover
John Crouse
So did all Defender bulkheads come slathered in caulk? I don't mean the black tacky strip caulk. The one I'm working on is out of a NAS D110 and it has white fairly rigid caulk generously spread over the seams and in the corners.
My plan is to cut out the big pieces and see what the paint stripping bath does to the rest. Thoughts?
Series bulkheads didn't have this crap......
Old November 16th, 2012, 07:18 PM
burn the caulk off with a weed burner or propane / mapp torch
Old November 16th, 2012, 08:01 PM
Just take it to the stripper. All that will come off. Then do the demolition.
Old November 17th, 2012, 08:07 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The new bulkheads I have seen do not have the seam sealer. The used ones do because if you do not have the seams sealed they can leak. When I took mine to have it galvanized they wanted everything off of it. It seems that the acid bath doesn't last as long if they get paint and other stuff in the bath. Also as a note if it is a used bulkhead you will get a bunch of debris in the finish unless you dip it a few times to get the stuff out of it. They ended up galvanizing it a couple of times to get the final finish right.
Land Rover 110
Old November 17th, 2012, 10:16 AM
61rover's Avatar
61rover
John Crouse
Once I get the large chunks of caulk off its going to A-1 Metal Strippers for the paint stripping bath. It will be clean and tidy before I take it to the galvanizer.
Old November 17th, 2012, 10:20 AM
There was a campaign to caulk bulkheads. The four I have seen have varying levels. One looks like it had four tubes used. They all still rusted.
Old November 17th, 2012, 11:06 AM
61rover's Avatar
61rover
John Crouse
Thanks Ron. That's what I was wondering.
Old November 17th, 2012, 12:56 PM
you'll need to get it off to galv it. But, worth putting back on as I have had streams of water cascading down the inside of both series and defender firewalls driving through heavy downpours or even just stitting parked up. Wondered why the four way flashers were goiung when I hadn't been in the car for days. Found the flasher relay filled with water, opened it up and cleared it out. Replaced the chipped and failing seam sealer right above that and no problems since. When I do repairs I try to layer them so that water runs down and over the overlapped portion and not down into the seam. But the factory did not always do that so the seam sealer is a good idea. Put it on over your primer and under your paint.
galvanizing
Bulkhead Rust TurkD90 Defender Technical Discussions 4 May 14th, 2005 05:06 AM
Bulkhead Questions JimC Defender Technical Discussions 19 October 27th, 2004 01:00 PM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
Help with installing bulkhead on chassis Chris Cox Defender Technical Discussions 2 June 5th, 2004 09:33 AM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
