premium fuel? - Defender Source
Old May 26th, 2012, 01:46 AM
petminded's Avatar
petminded
David
1995 Defender 90- Yellow- Soft Top
premium fuel?
hello all!
new here if you could not already tell (after all im still looking for the spellcheck)
in my '95 defender 90 i use regular fuel. recently i was cleaning the mold build up out of the pages of my land rover's owners manual. i saw that premium (91 octane or better) grade fuel is recomended.
with 137k + on my D90 im still wondering if i am doing harm using regular gas? after all i get only 12 mpg! HELP PLEASE
Old May 26th, 2012, 08:39 AM
nwp's Avatar
nwp
Nathan Patterson
1994 D-90
12 mpg is not far off. In fact it's normal if you have a heavy load of accessories or an older truck. I can get 15 mpg in my 1994 D-90 but that is with an empty truck immediately after a new exhaust and plugs.
Old May 26th, 2012, 08:54 AM
You are doing harm if you experience pinging (preignition) under acceleration or heavy load. Otherwise, no not really.
Old May 26th, 2012, 09:40 AM
I've got armor and 255's and mud flaps I can still get 15 if I drive conservatively. My rNge rover gets 8-13. Yeas you should use premium fuel it will help your fuel economy, I always have used BP or Shell I get best results from shell.
As for 12 mpg is your truck stock? Have you done much maintenance on it?
Old May 26th, 2012, 12:49 PM
Yup, what he said. I'm getting about 17 plus a little on the highway with the LeWB, 4.2 V8. ~120K on the engine. Running el cheapo regular gas with 10% ethanol in it.
Old May 26th, 2012, 12:55 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
If you're still at sea level, Huntington Beach, you should run the premium. At high elevation, regular is fine.
Old May 30th, 2012, 09:40 PM
petminded's Avatar
petminded
David
wow! thanks for all the help. it is as stock as they come (except the a/c- but i never use it). and im not always a conservative driver. i changed the oil over the memorial day wkend. no one had my air filter in stock, so that will come soon.
as for changing the spark plugs; any suggestion on the type? or does anything decent work well? also where can i look up the gap for the plugs?
Old May 31st, 2012, 07:09 AM
Plug gap is in the owners manual.
NGKBPR5EY for plugs.
fuel
