Preferred method convert to four hole seats - Defender Source
Old March 18th, 2016, 09:28 AM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
I have some used seats coming in from Jpound to replace the original ripped seats in my 110. My current seats are 8 hole base design. Do most folks drill/tap new holes or use some other method of conversion? Thanks
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old March 18th, 2016, 09:48 AM
There isnt enough material to tap, it is just sheet metal. You will need nuts, bolts and washers or some other method of fabricating a backing plate.
Old March 18th, 2016, 10:06 AM
One way is just to use four of the existing 8 holes in the seat box. Offset the seats slightly in or out.
Old March 18th, 2016, 11:07 AM
ontheway's Avatar
ontheway
Dave
I haven't seen or mocked up the 4 hole seats yet. So given your advice the new seats should line up unless the fabricator that fateful day in 86 had too many pints the night prior.
Old March 18th, 2016, 11:22 AM
Food for thought. If you move them out you are snug up against the door. If you move them in a center console and/or the seat belt buckles may not fit right.
Old March 18th, 2016, 11:34 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I enlarged the inner holes and used them. Compared to the NAS seatbox I have they were the same or very close in spacing.
Old March 18th, 2016, 11:43 AM
Originally Posted by ontheway View Post
I haven't seen or mocked up the 4 hole seats yet. So given your advice the new seats should line up unless the fabricator that fateful day in 86 had too many pints the night prior. Thanks
Yes. They line up fine. I did this in my truck. I'll snap a pic later.
Old March 18th, 2016, 08:37 PM
I put mine to the outside. I have a series style middle seat and needed the space. They should fit either way depending on what is in the center.
They bolt into a backing plate with captive nuts. There should be no drilling.
Old March 18th, 2016, 09:17 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You could also change out the bottom runners and just bolt the new seats on top of them and still use the 8 holes. I have done this a couple of times.
Land Rover 110
Prefered method for drilling holes in the body cabell Defender Technical Discussions 8 November 4th, 2010 11:00 PM
Best method to clean a gas tank devinchi Defender Technical Discussions 16 April 10th, 2008 05:50 PM
WTT: 97 center console cubby tray (hole for no hole) fleabus Wanted 3 December 23rd, 2007 10:59 PM
Preferred tool for flare trimming? KevinNY Defender Technical Discussions 6 February 26th, 2007 09:33 PM
Adding a Side Tank - Alternate Filler Method JimC Misc. Chit-Chat 6 October 25th, 2004 12:29 PM
