Preferred Disco t-case if you have a choice? - Defender Source
Old March 30th, 2015, 09:03 AM
kilr4d
1999 110 TD5
Question Preferred Disco t-case if you have a choice?
Assembling parts/pieces prior to my 110's arrival, definitely would like to get a 1.2 transfer case and they seem to cheap and plentiful from wrecking yards around here:
Early model D2:
Later model D2:
Pros/cons to either for installing in a 1999 TD5?
Old April 1st, 2015, 09:40 AM
kilr4d
1999 110 TD5
Anyone?
Old April 1st, 2015, 10:55 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Later ones were the LT230Q.... Q meaning "quiet"... although I've never really had any cause to think a normal box is "noisy", but I suppose every decibel helps.
Bear in mind, some of the D2 boxes didn't have a difflock fitted (or didn't have the linkage on it... the diff is still inside the box), some are as easy as bolting on the operating arm with a 13mm nut (you'll see the threaded shaft sticking out of the box), some will need a kit from ashcrofts to add the lever
In my mind, I'd go for the one with the lowest mileage....cost depending of course.
Old April 1st, 2015, 01:48 PM
kilr4d
1999 110 TD5
Thanks. I'll buy the one with 39k miles.
-John
Old April 2nd, 2015, 03:17 PM
kilr4d
1999 110 TD5
Alright...just showed up. Gave the shaft a quick spin...quiet and smooth.
Would you guys bother taking it apart for inspection with only 39k miles?
Old April 2nd, 2015, 03:20 PM
Remove the shift interlock solenoid. Change the 3 shaft seals and the intermediate shaft o-ring.
aka rover's Avatar
aka rover
ed angel
95 D90
Drain fluid remove bottom cover inspect gears for wear metal . Lock the diff feel for slop , if all looks and feels good replace the seals and run it .
And what those guys ^^^^ said didn't notice with my mini pics on my phone it was a D2 unit .
85 D110 3.5 3 DR
Old April 2nd, 2015, 03:23 PM
Check the diff lock and low/high range shifters make sure it all works. Check that the diff lock light switch is adjusted correctly.
Old April 2nd, 2015, 04:51 PM
kilr4d
1999 110 TD5
Pull the interlock solenoid.
Will there be a cover on my 110 T-Case to go over the hole?
Diff lock moves freely with a positive "click" both ways. Input shaft spins smoothly in either range. High/low range shifter seems REALLY stiff. Is that because of the solenoid or because it might never have been used?
Procedure for that?
Old April 2nd, 2015, 05:00 PM
The solenoid is under a cover already. Unbolt it and remove the guts. It will be obvious.
Read the workshop manual (easy to download) to find the switch adjustment procedure.
disco
Black Soft Top (Badger preferred) Needed Dirty Wanted 2 September 20th, 2013 12:29 PM
looking to buy 109 4dr preferred mountainviewrover Wanted 5 March 13th, 2012 06:00 PM
So you think you have rust? ECR Misc. Chit-Chat 109 February 5th, 2010 06:22 PM
Preferred tool for flare trimming? KevinNY Defender Technical Discussions 6 February 26th, 2007 09:33 PM
You think you have it bad...... UKlandyandy Misc. Chit-Chat 1 November 20th, 2004 03:58 PM
