Preferred Coolant and Synthetic Engine Oil - Defender Source
Old November 30th, 2015, 04:18 PM
jperakis
James Perakis
94 ST
Did a search and found a wide range of feedback.
Would like to get a concise enough answer
what is your preferred coolant and engine oil?
remember two things...
Old November 30th, 2015, 04:25 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
I use Peak Final Charge 50/50 Extended Life Antifreeze, its probably overkill for this application but still.
You can't really go wrong with Rotella or Mobil on oil, but I am sure there are plenty of opinions on that front.
Old November 30th, 2015, 04:26 PM
A V8? Any normal coolant is fine and really any engine oil. It helps to have an oil designed for flat tappet lifters. A diesel engine oil is usually the simplest route. Synthetics are a waste of time as it has little effect on wear rates with these old engine designs, based on my review of oil analysis.
Old November 30th, 2015, 04:31 PM
jperakis
James Perakis
94 ST
Originally Posted by Red90 View Post
A V8?
Yes this is for a NAS 3.9 V8
------ Follow up post added November 30th, 2015 01:32 PM ------
Thanks!
Re: engine oil... anyone know what the book says? 10w30?
Old December 1st, 2015, 12:39 AM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
I use 15w30 in everything. That way, if I have to add oil to the Tdi, I can't grab the wrong oil off the shelf by mistake.
Black Rhino Lives Matter
Old December 1st, 2015, 05:30 AM
Grover's Avatar
Grover
Thumbs up
The experts use Castrol 10W-30 GTX
Change every 3 months/3k miles
I've been using this oil for ten years in my D90 with no issues, no sludge, no build up.
Everyone has ther own opinion on oil. The most important thing is to change using the interval mentioned above...
Cheers...
Old December 1st, 2015, 08:04 AM
87 D110 (Ruby)
Be sure it is "OR" - if you don't use the truck daily you may not get to 3K in 3 months - I never do.
Old December 1st, 2015, 08:10 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
What 'experts' are recommending 10w-30? Unless you live in the cold.
I'm running Rotella 15w-40 thinking as most do here.
Old December 1st, 2015, 08:32 AM
Thanks!
As others pointed out, literally any "green" coolant from Advance Auto / AutoZone, and I use Rotella 15w40 for oil (which as Red90 pointed out is technically a diesel oil, I use it in all my "non-modern" cars).
Old December 1st, 2015, 08:43 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Peak 50/50 and Rotella 15-40 in all of my 90s vintage V8s.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old December 1st, 2015, 10:04 AM
I use 15w40 Rotella in the summer and 5w30 Castrol in the winter.
Old December 1st, 2015, 10:15 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Green prestone and 15/40 rotella or 10/40 mobile 1 in summer and 5/30 in winter. That "experts" comment cracked me up--- we are all kings of our castles :-)
Old December 1st, 2015, 03:36 PM
I run rotella 5w40 synthetic and off the shelf anti-freeze 50/50 mix. All reasonably priced and available at Walmart.
Old December 1st, 2015, 03:43 PM
jperakis
James Perakis
94 ST
thanks to all for the replies.
interesting about the diesel oil.
Final question regarding coolant... the big thing is I need to ensure the coolant is silicate free, correct? Helps protect the aluminum engine?
Old December 1st, 2015, 03:55 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
you are over thinking it bud. 50/50 Peak on sale and 15/40 Rotella. synthetic is snake oil for these English tractors. save you pennies for shit you haven't even dreamed will go wrong yet.
Old December 1st, 2015, 04:29 PM
Amsoil 10w40 cant be beat
Use the minimum amount of coolant for your climate, distilled water is a must!
coolant, engine
V8 Engine Oil - Synthetic vs Semi Synthetic nickt Defender Technical Discussions 68 September 18th, 2016 09:38 AM
Black Soft Top (Badger preferred) Needed Dirty Wanted 2 September 20th, 2013 12:29 PM
looking to buy 109 4dr preferred mountainviewrover Wanted 5 March 13th, 2012 06:00 PM
Synthetic oil to dino oil. discotdi Defender Technical Discussions 8 June 19th, 2011 09:18 AM
Preferred tool for flare trimming? KevinNY Defender Technical Discussions 6 February 26th, 2007 09:33 PM
