Prefered method for drilling holes in the body - Defender Source
Old November 3rd, 2010, 03:25 PM
cabell's Avatar
cabell
Cabell Crowther
I need to drill some holes in the tub for NAS tail lights. I've used a hole saw and a wood template in the past but surely there is a better way? Maybe I just need a hole saw with finer teeth?
Old November 3rd, 2010, 03:45 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
Hole saw works, but you need to control the speed( keep it slower) and spray WD-40 around the bit and material while drilling.
For smaller holes, I use a step drill.
What tree?
Old November 3rd, 2010, 05:26 PM
PaulMc's Avatar
PaulMc
Paul McConnell
1989 110 2.5 Turbo-Diesel
Q.Max Hole Punches make a neat burr free hole and don't have te be be centred like a holesaw or a step drill.
I don't know what you call them in the US, but this is what I'm referring to -
http://cgi.ebay.com/Q-Max-Sheet-Meta...-/310226500399
Paul.
1989 Arles Blue 2.5TD 110 Hardtop
1999 Epsom Green Discovery II 4.0 V8i 'XS'
Old November 3rd, 2010, 06:09 PM
Chaucer
Will
93 110 | 97 90
We call that a "knockout punch" in the US. They're nice.
Old November 3rd, 2010, 09:20 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Tape the part you are going to drill with several layers of tape. It will help minimize scratches.
Old November 3rd, 2010, 09:28 PM
I opened the holes on the 130 up with a die grinder and carbide burr,look in the cabinet I keep the air tools in. If its not there I can bring it down next trip.
Old November 3rd, 2010, 10:32 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
[QUOTE=EWR;249024]Hole saw works, but you need to control the speed( keep it slower) and spray WD-40 around the bit and material while drilling.
X2 on that, if you are going to use a hole saw be careful. I had a couple of "incidents" doing the same thing on my truck.
Old November 4th, 2010, 08:51 AM
Grover's Avatar
Grover
Thumbs up Adjustable Circle Cutter
I've have luck with this tool on flat surfaces. The trick is to keep it square with the hand drill. Also, with a single cutting edge, you get less chatter.
Cheers...
Old November 4th, 2010, 11:00 PM
Tino.R's Avatar
Tino.R
Tino Rebelo
67/series IIA
if you use a hole saw run it backwards will cut threw alum. the knock out punch any electrician has one in the work van as they are expens.to buy.
body
Dilling holes in aluminum body panels fenwaystan Defender Technical Discussions 1 March 22nd, 2008 01:14 PM
Holes in body kennybahr Defender Technical Discussions 23 January 22nd, 2008 07:23 PM
lifting the body (not plastic surgery :-) cbass Defender Technical Discussions 11 April 25th, 2005 12:14 PM
Drilling holes for rear light guards khatadin Defender Technical Discussions 8 January 5th, 2005 08:43 PM
body work on aluminum mattdh Defender Technical Discussions 11 July 4th, 2004 02:47 PM
